Problemsolving can be painful!
Maybe this will make it easier...
The Documentation is always a good start if you experience Problems.
Maybe your Question is already covered in of the Tags?
Maybe it's an Error in your OS?
As Grommunio only makes use of certain Operating-Systems you likely get
better help on Server-Problems at the individual Support-Channels.
IRC https://en.opensuse.org/openSUSE:IRC_list @ Libera
IRC https://wiki.debian.org/IRC @ OFTC
Guides and Documentations
How to report a Problem?
This is an template to illustrate how you could describe your problem in a way
anyone will have it easy to understand your problem, the steps needed to
reproduce it and what you might have tried already to resolve the Problem.
Replace/Remove the TPL: Textblocks and "Quotes"
## TPL: Short Problem-Description
TPL: If User X wants to do Y, Z is happening...
### To recreate TPL: problem-X
- TPL: Open X
- - TPL: Create Y
- - TPL: Configure Z
- TPL: Select N....
TPL: Since an Update we are not longer able to Login via $PROTOCOL.
### TPL: How we narrowed it down to XYZ
- TPL: Working Protocols
- - TPL: Outlook, Web, ActiveSync, DAV
- TPL: Broken Protocols
- - TPL: IMAP-Connect with ThunderX and/or ArchiveY isn't possible
[ ] System has the latest Updates and was rebooted/restarted
zypper ps -s has nothing to report
Provide System-Information
To show currently installed Package-Versions you could Copy-Paste the Output from following Command instead of this > QUOTE!
printf '### Installed Packages\n\n```\n%s\n````\n' "$(rpm -qa *grom* |sort)"
Make sure these quotes are so called acute:` and not ’, ' or " when you copy the Text. This might happen with Putty IIRC.
More in detail and only from the grommunio repositories
RPM-Based
rpm -q -a --qf "%-40{Name}%-30{Version}%{Release}:%{Vendor}\n" ${1-} | sort | awk -F: '/grommunio/ {print $1}'
DEB-Based
dpkg-query -Wf '${Package;-40}${Version;-30};${Maintainer}\n' ${1-} | awk -F\; '/(grommunio|gromox)/ {print $1}';
