Bei einem User bekomme ich unter "Mobile Devices" nur die Meldung
The server encountered an error while processing the request.
Im Admin API Log erscheinen folgende Zeilen:
[2023-08-30 12:50:23.917742]: [ERROR] (flask.app) Traceback (most recent call last):
[2023-08-30 12:50:23.917742]: File "/usr/lib/python3.6/site-packages/flask/app.py", line 1838, in full_dispatch_request
[2023-08-30 12:50:23.917742]: rv = self.dispatch_request()
[2023-08-30 12:50:23.917742]: File "/usr/lib/python3.6/site-packages/flask/app.py", line 1824, in dispatch_request
[2023-08-30 12:50:23.917742]: return self.view_functionsrule.endpoint
[2023-08-30 12:50:23.917742]: File "./api/core.py", line 179, in wrapper
[2023-08-30 12:50:23.917742]: return call()
[2023-08-30 12:50:23.917742]: File "./api/core.py", line 144, in call
[2023-08-30 12:50:23.917742]: ret = func(*args, **kwargs)
[2023-08-30 12:50:23.917742]: File "./endpoints/domain/users.py", line 251, in getUserSyncData
[2023-08-30 12:50:23.917742]: data = client.getSyncData(Config["sync"].get("syncStateFolder", "GS-SyncState"))
[2023-08-30 12:50:23.917742]: File "./services/exmdb.py", line 23, in <lambda>
[2023-08-30 12:50:23.917742]: return lambda *args, **kwargs: target(self.__homedir, *args, **kwargs)
[2023-08-30 12:50:23.917742]: pyexmdb.ExmdbProtocolError: exmdb call failed: Dispatch error
[2023-08-30 12:50:23.918993]: [WARNING] (flask.app) GET /api/v1/domains/1/users/2/sync? from 'meine ip' -> 500 '{"message":"The server encountered an error while processing the request."}\n'
Wie kann man den Fehler beheben?
Nach der Reparatur der Datenbank haben sich die Fehlermeldungen geƤndert
[WARNING] (flask.app) GET /api/v1/service/wipe/<username>?devices=<xxx> from ::1 -> 404 '{"message":"User not found"}\n'
[WARNING] (flask.app) POST /api/v1/service/wipe/<username>?devices=<xxx> from ::1 -> 404 '{"message":"User not found"}\n'
