public folder / permission problems / not able to revoke public folder / permission setting not working
public folder got some issues
the issue in german (the info / hint to set the permissions btw is not working)
https://community.grommunio.com/d/112-mails-im-public-folder
a) permission problems ... for starters once you've moved a mail (copy or move) to the public folder
no matter what permissions you set you cant move or delete an email
b) if you remove a user on the admin webIF from the public folder the user still has access to the public folder
... anyhow caused by problem a) the user is unable to delete emails ... not sure if this is a bug or a feature
c) permission setting on the subfolder itself is not working
... the user himself can change permissions on a folder he is not owner ... not that big deal cuz its a public folder ..
problem if the user can delete mail within the public folder
d) if you want ro get rid of the public folder you created, i am not talking to disable it and keep it on the backup
just get rid of it ... there is no way ... the public folder is not gone
