Yes, yes... I read about the fqdn/hostname... but it was (mainly) working just fine until in completely broke down...
Did the update/upgrade a few minutes ago...
It is still not working. Nothing changed (for me, at least)
But the problem is not in the "unreachability" of the server - it "crashes" when processing the python code... some type/map "mismatch/unreferenced" - I logged the error a few messages above
This has to do with "something else"... maybe some package got "sucked" from an wrong repo or something...
basically it crashes and throws this:
sqlalchemy.exc.InvalidRequestError: One or more mappers failed to initialize - can't proceed with initialization of other mappers. Triggering mapper: 'mapped class MLists->mlists'. Original exception was: reverse_property 'mlist' on relationship MLists.user references relationship Users.mlist, which does not reference mapper mapped class MLists->mlists
What can I possibly do with this "alchemy" stuff? What to reinstall? Or what libraries should be installed? Or some other package? (grommunio-admin-xxx?)
Can you list the current python* libraries which should be used?
I have this on the Debian 11 server:
python-apt-common 2.2.1
python-pip-whl 20.3.4-4+deb11u1
python3 3.9.2-3
python3-acme 1.12.0-2+deb11u1
python3-apt 2.2.1
python3-argcomplete 1.8.1-1.5
python3-attr 20.3.0-1
python3-blinker 1.4+dfsg1-0.3
python3-certbot 1.12.0-2
python3-certbot-nginx 1.10.1-1
python3-certifi 2020.6.20-1
python3-cffi-backend:amd64 1.14.5-1
python3-chardet 4.0.0-1
python3-click 7.1.2-1
python3-colorama 0.4.4-1
python3-configargparse 1.2.3-1
python3-configobj 5.0.6-4
python3-cryptography 3.3.2-1
python3-dateutil 2.8.1-6
python3-dbg 3.9.2-3
python3-dbus 1.2.16-5
python3-debconf 1.5.77
python3-debian 0.1.39
python3-debianbts 3.1.0
python3-decorator 4.4.2-2
python3-dev 3.9.2-3
python3-distro 1.5.0-1
python3-distutils 3.9.2-1
python3-dnspython 2.0.0-1
python3-firewall 0.9.3-2
python3-flask 1.1.2-2+deb11u1
python3-flask-sqlalchemy 2.1-4
python3-gi 3.38.0-2
python3-httplib2 0.18.1-3
python3-icu 2.5-1+b2
python3-idna 2.10-1
python3-importlib-metadata 1.6.0-2
python3-isodate 0.6.0-2
python3-itsdangerous 1.1.0-3
python3-jellyfish 0.8.2-1+b2
python3-jinja2 2.11.3-1
python3-josepy 1.2.0-2
python3-jsonschema 3.2.0-3
python3-jwt 1.7.1-2
python3-lazy-object-proxy 1.5.2-1
python3-ldap3 2.8.1-1
python3-lib2to3 3.9.2-1
python3-markupsafe 1.1.1-1+b3
python3-mattermostdriver 7.3.2-1+14.5
python3-minimal 3.9.2-3
python3-more-itertools 8.12.0-1+1.8
python3-multidict 5.1.0-1
python3-mysqldb 1.4.4-2+b3
python3-nftables 0.9.8-3.1+deb11u1
python3-openapi-core 0.13.7-1+7.17
python3-openapi-schema-validator 0.1.5-1+10.7
python3-openapi-spec-validator 0.2.9-1+8.7
python3-openssl 20.0.1-1
python3-parse 1.19.0-1+22.10
python3-parsedatetime 2.6-1
python3-pip 20.3.4-4+deb11u1
python3-pkg-resources 52.0.0-4
python3-psutil 5.8.0-1
python3-pyasn1 0.4.8-1+1.6
python3-pycurl 7.43.0.6-5
python3-pydantic 1.7.4-1
python3-pyexmdb 1.11.0.58baa16-1+17.2
python3-pyinotify 0.9.6-1.3
python3-pyparsing 2.4.7-1
python3-pyrsistent:amd64 0.15.5-1+b3
python3-pysimplesoap 1.16.2-3
python3-redis 3.5.3-2
python3-reportbug 7.10.3+deb11u1
python3-requests 2.25.1+dfsg-2
python3-requests-toolbelt 0.9.1-1
python3-rfc3339 1.1-2
python3-rfc3339-validator 0.1.5-1+9.3
python3-selinux 3.1-3
python3-setuptools 52.0.0-4
python3-simplejson 3.17.2-1
python3-six 1.16.0-2
python3-slip 0.6.5-2
python3-slip-dbus 0.6.5-2
python3-sqlalchemy 1.3.22+ds1-1
python3-sqlalchemy-ext:amd64 1.3.22+ds1-1
python3-strict-rfc3339 0.1.5-1+13.2
python3-systemd 234-3+b4
python3-tz 2021.1-1
python3-urllib3 1.26.5-1~exp1
python3-uwsgidecorators 2.0.19.1-7.1
python3-websockets 8.1-1
python3-werkzeug 1.0.1+dfsg1-2+deb11u1
python3-wheel 0.34.2-1
python3-yaml 5.3.1-5
python3-zipp 1.0.0-3
python3-zope.component 4.3.0-3
python3-zope.event 4.4-3
python3-zope.hookable 5.0.1-1+b2
python3-zope.interface 5.2.0-1
python3.9 3.9.2-1
python3.9-dbg 3.9.2-1
python3.9-dev 3.9.2-1
python3.9-minimal 3.9.2-1
As I cannot access the Admin UI I cannot check for any "changes/progress" regarding modifying user parameters, PFs etc.
