rpnmtb Hello and appreciate the support. Unable to send email from a Mac client or iOS client. I get the following error in zcore: exmdb_client: HX_inet_connect to [::1]:5000: Connection refused No issues with receiving. No other system issues. IPV6 is enabled as well. I can telnet to the port from the grommunio server on ::1 5000. I can also send email from windows clients and the web client.
rpnmtb I am also seeing this in the sync error log when the above error occurs in zcore log: 21/11/2023 16:06:36 [ 1442] [ WARN] [.....@.....] Grommunio->openMessageStore('christos@adamidis.ca'): Could not get storestables information 0x80004005 21/11/2023 16:06:36 [ 1442] [FATAL] [.....@.....] Exception: (AuthenticationRequiredException) - Grommunio->Logon(): User '.....@a......' has no default store I assume that the connection refused is a result of the sync error. Not sure how to add a default store for the user.
millilenium Same problem here - even after fresh install and import /var/lib/gromox I resetted the mobile device and now it just shows this error - preview is possible in the mails but nothing more
millilenium for me it's clear now - on my fresh install the repository changed to community (either I typed all supported licenses). I changed to supported, made zypper dup and everything is fine now!
THE_FRICKLER With the latest update from today the problem seems to be solved. In my installation Community with Suse 14.5 (first start Febr. 2022) the error is gone and all ios-clients are sycronized and stay in this status
rpnmtb THE_FRICKLER Still getting exmdb_client: HX_inet_connect to [::1]:5000: Connection refused errors even after updating and still cannot send emails.
rpnmtb mwilliams Name : grommunio-admin-api Version : 1.14.1.fef7240-lp155.86.1 Name : grommunio-admin-api-bash-completion Version : 1.14.1.fef7240-lp155.86.1 Name : grommunio-admin-common Version : 19.fca083c-lp155.15.1 Name : grommunio-admin-web Version : 2.8.0.18.a39ffbd-lp155.67.1 Name : grommunio-antispam Version : 3.7.3-lp155.6.1 Name : grommunio-antispam-debuginfo Version : 3.7.3-lp155.6.1 Name : grommunio-antispam-debugsource Version : 3.7.3-lp155.6.1 Name : grommunio-archive Version : 1.3.13.g137.d1b0df1b-lp155.5.12 Name : grommunio-archive-debuginfo Version : 1.3.13.g137.d1b0df1b-lp155.5.12 Name : grommunio-archive-debugsource Version : 1.3.13.g137.d1b0df1b-lp155.5.12 Name : grommunio-auth Version : 0.2.16.e187c26-lp155.30.1 Name : grommunio-chat Version : 7.8.0-lp155.8.1 Name : grommunio-common Version : 21.8eb9e0e-lp155.34.1 Name : grommunio-cui Version : 1.0.256.5c857a6-lp155.59.1 Name : grommunio-dav Version : 1.3.16.17b01b4-lp155.1.1 Name : grommunio-dbconf Version : 1.1.1.da20a46-lp155.4.11 Name : grommunio-dbconf-debuginfo Version : 1.1.1.da20a46-lp155.4.11 Name : grommunio-dbconf-debugsource Version : 1.1.1.da20a46-lp155.4.11 Name : grommunio-error-pages Version : 1.0.10.bb2df37-lp155.10.1 Name : grommunio-files Version : 25.0.12-lp155.4.1 Name : grommunio-imapsync Version : 2.264-lp155.1.1 Name : grommunio-index Version : 0.1.37.74e396b-lp155.40.2 Name : grommunio-index-debuginfo Version : 0.1.37.74e396b-lp155.40.2 Name : grommunio-index-debugsource Version : 0.1.37.74e396b-lp155.40.2 Name : grommunio-keycloak Version : 22.0.5-lp155.1.1 Name : grommunio-office Version : 7.4.1-lp155.5.3 Name : grommunio-office-debuginfo Version : 7.4.1-lp155.5.3 Name : grommunio-office-fonts Version : 7.4.1-lp155.5.3 Name : grommunio-release Version : 2023.11.1-lp155.7.1 Name : grommunio-setup Version : 1.0.103.7786fbd-lp155.41.1 Name : grommunio-sync Version : 2.0.38.12b2e4f-lp155.139.1 Name : grommunio-web Version : 3.6.0.d28e88b9-lp155.4.3 Name : gromox Version : 2.17.122.6a37e39-lp155.37.1 Name : gromox-debuginfo Version : 2.17.122.6a37e39-lp155.37.1 Name : gromox-debugsource Version : 2.17.122.6a37e39-lp155.37.1
