(I realize there seem to be several fixes to IMAP in the code, that have not yet made it into the packages in the community repo - so hopefully this issue may already be fixed?)
I am currently trying out grammm/gromox in any way I can, so I attempted to import an IMAP mailbox using imapsync. Unfortunately the program always fails at the first message.
My (redacted) cmd:
imapsync --host1 mail1.lan --user1 florian --password1 xxx --host2 grammm.lan --user2 "florian@landomain.lan" --password2 XXX --automap --sslargs2 SSL_verify_mode=0 --debug --debugimap2 --debugmemory
And the (shortened) output of the run:
Host2 IP address: 10.10.10.220
Host2 banner: * OK localhost service ready
Read: 2 OK logged in
Host2: success login on [grammm.lan] with user [florian@landomain.lan] auth [LOGIN]
Host2: found ID capability. Sending/receiving ID, presented in raw IMAP for now.
Sending: 4 ID ("name" "imapsync" "version" "1.977" "os" "linux" "vendor" "Gilles LAMIRAL" "support-url" "https://imapsync.lamiral.info/" "date" "23-Dec-2019 20:18:02 +0000" "side" "host2")
Read: 4 BAD command not supported or parameter error
Sending literal: 17 APPEND "Sent Items" (\Seen) "04-Nov-2010 17:36:05 +0000" {1756}
Sending: 17 APPEND "Sent Items" (\Seen) "04-Nov-2010 17:36:05 +0000" {1756}
Read: + ready for additional command text
Sending: Message-ID: <4CD2EEC2.7080200@gmx.at>
[... message body ...]
Read: * BAD command not supported or parameter error
I've tried other folders and different options, but I never get past the first message...
