Hi, I try to install latest Grommunio on a Synology NAS in Virtual Machine Manager. When I run the setup, after all the updates, it can't create the mySQL database. This mainly fails because mySQL is not running, but I also don't get it to run at all.
Dez 07 18:20:50 mailbox mysql-systemd-helper[14569]: Checking MySQL configuration for obsolete options...
Dez 07 18:20:50 mailbox mysql-systemd-helper[14569]: Trying to run upgrade of MySQL databases...
Dez 07 18:20:51 mailbox mysql-systemd-helper[14569]: Stale files from previous upgrade detected, cleaned them up
Dez 07 18:20:51 mailbox mysql-systemd-helper[14569]: Running protected MySQL...
Dez 07 18:20:51 mailbox mysql-systemd-helper[14569]: Waiting for MySQL to start
Dez 07 18:21:51 mailbox mysql-systemd-helper[14569]: MySQL is still dead
Dez 07 18:21:51 mailbox mysql-systemd-helper[14569]: MySQL didn't start, can't continue
Dez 07 18:21:51 mailbox systemd[1]: mariadb.service: Control process exited, code=exited, status=1/FAILURE
Dez 07 18:21:51 mailbox systemd[1]: mariadb.service: Failed with result 'exit-code'.
Dez 07 18:21:51 mailbox systemd[1]: Failed to start MariaDB database server.
Is there anyone who has an idea why a fresh install is failing so badly?
