After a fresh install of the Grommunio-Appliance (based on the published SuSE-based ISO-Image), I created an Organization, Domain and User.
When the User logs into the Webmail Frontend, the web-interface reports an error:
"Could not load the contents of this folder. (null) (An invalid parameter was passed to a function or remote procedure call)"
journalctl -f shows:
May 01 20:59:35 localhost zcore[1730]: get_store_properties /var/lib/gromox/domain/testdomain.tld: failed
(repeated several times)
The directory /var/lib/gromox/domain/testdomain.tld exists:
drwxrwx--- 9 grommunio gromox 110 May 1 20:59 testdomain.tld
Never mind the name of the domain, I just created an anonym domain for demonstration purpose, it's the same problem with correctly configured DNS-zones.
It's just a test-installation, so I deleted the VMs several times and reinstalled from scratch - unfortunately no change.
The installed versions are:
grommunio-admin-api-1.17.2.73dcb45-lp156.54.1.noarch
grommunio-admin-common-42.e17ec55-lp156.37.1.noarch
grommunio-admin-web-4.0.0.2.a04db96-lp156.126.1.noarch
grommunio-antispam-3.11.1-lp156.1.2.x86_64
grommunio-common-27.db4a83f-lp156.51.1.x86_64
grommunio-cui-1.1.1.6b3ec18-lp156.4.1.noarch
grommunio-dav-1.5.3.ee3394a-lp156.1.1.noarch
grommunio-dbconf-1.1.1.da20a46-lp156.29.2.x86_64
grommunio-error-pages-1.0.10.bb2df37-lp156.30.1.noarch
grommunio-imapsync-2.290-lp156.1.1.noarch
grommunio-index-1.3.0.g2bd8a8c-lp156.39.2.x86_64
grommunio-release-2025.1.2-lp156.1.1.x86_64
grommunio-setup-1.1.13.4ec354b-lp156.67.1.noarch
grommunio-sync-2.2.2.91fc33a-lp156.3.1.noarch
grommunio-web-3.13.1.g9bc01d227-lp156.254.1.noarch
gromox-2.45.158.gc709571-lp156.18.1.x86_64
gromox-debuginfo-2.45.158.gc709571-lp156.18.1.x86_64
gromox-debugsource-2.45.158.gc709571-lp156.18.1.x86_64
grub2-theme-grommunio-1-lp156.20.1.noarch
patterns-grommunio-1-lp156.9.1.x86_64
plymouth-theme-grommunio-1-lp156.20.1.noarch
system-user-grommunio-10-lp156.2.1.noarch
system-user-gromox-9-lp156.5.1.noarch
systemd-coredump-grommunio-1-lp156.3.1.noarch
systemd-presets-branding-grommunio-2024.06-lp156.2.1.noarch
