For everyone who is interested
I couldn't find the Module so lets's build it ourself.
I haven't tested it yet but nginx -t
did seem to like it. Don't really know if it does an check on the module there but systemctl start nginx
did work as well.
whoami
root
mkdir src
cd src
apt-get build-dep nginx-full
git clone https://github.com/vozlt/nginx-module-vts.git
wget https://nginx.org/download/nginx-1.18.0.tar.gz
tar xfvz nginx-1.18.0.tar.gz
cd nginx-1.18.0/
#Here we look for our prefix..
nginx -V |& grep configure\ arguments |sed 's/.*prefix/--prefix/'
#now use it...
#add the end we add --add-dynamic-module= ../nginx-module-vts/
./configure --prefix=/usr/share/nginx --conf-path=/etc/nginx/nginx.conf --http-log-path=/var/log/nginx/access.log --error-log-path=/var/log/nginx/error.log --lock-path=/var/lock/nginx.lock --pid-path=/run/nginx.pid --modules-path=/usr/lib/nginx/modules --http-client-body-temp-path=/var/lib/nginx/body --http-fastcgi-temp-path=/var/lib/nginx/fastcgi --http-proxy-temp-path=/var/lib/nginx/proxy --http-scgi-temp-path=/var/lib/nginx/scgi --http-uwsgi-temp-path=/var/lib/nginx/uwsgi --with-compat --with-debug --with-pcre-jit --with-http_ssl_module --with-http_stub_status_module --with-http_realip_module --with-http_auth_request_module --with-http_v2_module --with-http_dav_module --with-http_slice_module --with-threads --with-http_addition_module --with-http_gunzip_module --with-http_gzip_static_module --with-http_sub_module --add-dynamic-module=../nginx-module-vts/
make modules
cp objs/ngx_http_vhost_traffic_status_module.so /usr/lib/nginx/modules/
echo "load_module /usr/lib/nginx/modules/ngx_http_vhost_traffic_status_module.so;" > modules-available/90-mod-vhost-traffic-status.conf
ln -s /etc/nginx/modules-available/90-mod-vhost-traffic-status.conf /etc/nginx/modules/enabled/
Please try out.. this was just copied together from history and added a few comments. I know what a hassle it can be so i thought i would share this bit which is in reallity easy as hell :-).
