WalterH Good morning WalterH,
your tip was good, I havent any old phones in the system, but I tried resync all phones and it helped. It toked whole weekend (I resynced one by one) and at the end it helped. Now gromox-http runs for 100% very shortly and returns to nearly 0% for most of the time.
I checked the grommunio-sync-error.log file and they are still some errors, like:
19/01/2026 10:51:29 [79138] [ WARN] [user@domain.com] SyncObject->Check(): object from type SyncMail: parameter 'to' contains an invalid email address '"'Name Surname'" <>'. Address is removed.
It is interesting that the 'Name Surname'" <>' is always local user which is in global addressbook
19/01/2026 10:51:41 [77164] [ERROR] [user@domain.com] TimezoneUtil::guessTZNameFromPHPName() no compatible timezone found for 'EUROPE/BERLIN'. Returning 'GMT Standard Time'. Please contact the grommunio dev team.
It is seen the reset tzdata did not helped.
19/01/2026 10:32:55 [77138] [ WARN] [user@domain.com] Not possible to determine class of request. Request did not contain class and apparently there is an issue with the HierarchyCache.
19/01/2026 08:46:05 [77164] [ WARN] [user@domain.com] Utils->GetFolderOriginFromId(): Unknown folder origin for folder with id '553131343563'
Is it possible to correct something to avoid this problems? Especially TimeZone? It seems this error is reported for each Calendar record sync.
