Hello Community,
I'm running grommunio on openSUSE Leap 15.6, fully patched. Here are the packages installed:
grommunio-setup-1.1.14.768d394-lp156.71.1.noarch
system-user-gromox-9-lp156.6.1.noarch
grommunio-office-fonts-7.4.1-lp156.6.37.noarch
grommunio-antispam-3.12.1-lp156.1.2.x86_64
grommunio-sync-2.4.2.579e166-lp156.21.1.noarch
grommunio-office-7.4.1-lp156.6.37.x86_64
gromox-3.3.138.m1389c9b-lp156.28.1.x86_64
grommunio-files-31.0.12-lp156.1.1.noarch
grommunio-web-3.16.28.g1fff4e6a3-lp156.376.1.noarch
grommunio-admin-common-44.9fd4fb3-lp156.47.1.noarch
grommunio-archive-1.3.13.g137.d1b0df1b-lp156.9.147.x86_64
grommunio-dav-1.6.3.284cd87-lp156.1.1.noarch
grommunio-chat-9.11.17-lp156.11.1.x86_64
jitsi-meet-branding-grommunio-2.0.10532-lp156.1.1.noarch
grommunio-admin-api-1.17.57.m730814f-lp156.18.1.noarch
grommunio-error-pages-1.0.10.bb2df37-lp156.22.1.noarch
grommunio-admin-web-4.0.0.25.bec1ac6-lp156.147.1.noarch
grommunio-common-29.5-lp156.10.1.x86_64
system-user-grommunio-10-lp156.6.1.noarch
While logged into the Archive Admin page as admin@local, I'm seeing an issue in the grommunio archive interface; when I navigate to the Archiver Monitor Statistics page, the chart does not populate. Instead I get the following:
If I try to open the image in a separate tab, I get the following result:
Here is the associated link to the chart:
https://<my.emailserver>/archive/index.php?route=stat/graph×pan=daily&uid=
I believe I've identified some coding issues in PieChart.php caused by my choice of using PHP 8 vs. PHP 7 (Google Gemini is leading me to believe this, and the errors I was seeing php-fpm.log prior to the edits have gone away).
Here is the original file:
`<?php
/* Libchart - PHP chart library
* Copyright (C) 2005-2011 Jean-Marc Tr閙eaux (jm.tremeaux at gmail.com)
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see http://www.gnu.org/licenses/.
* Pie chart.
* @author Jean-Marc Tr閙eaux (jm.tremeaux at gmail.com)
class PieChart extends Chart {
protected $pieCenterX;
protected $pieCenterY;
* Constructor of a pie chart.
* @param integer width of the image
* @param integer height of the image
public function PieChart($width = 600, $height = 250) {
parent::Chart($width, $height);
$this->plot->setGraphPadding(new Padding(15, 10, 30, 30));
* Computes the layout.
protected function computeLayout() {
$this->plot->setHasCaption(true);
$this->plot->computeLayout();
// Get the graph area
$graphArea = $this->plot->getGraphArea();
// Compute the coordinates of the pie
$this->pieCenterX = $graphArea->x1 + ($graphArea->x2 - $graphArea->x1) / 2;
$this->pieCenterY = $graphArea->y1 + ($graphArea->y2 - $graphArea->y1) / 2;
$this->pieWidth = round(($graphArea->x2 - $graphArea->x1) * 4 / 5);
$this->pieHeight = round(($graphArea->y2 - $graphArea->y1) * 3.7 / 5);
$this->pieDepth = round($this->pieWidth * 0.05);
* Compare two sampling point values, order from biggest to lowest value.
* @param double first value
* @param double second value
* @return integer result of the comparison
protected function sortPie($v1, $v2) {
return $v1[0] == $v2[0] ? 0 :
$v1[0] > $v2[0] ? -1 :
1;
* Compute pie values in percentage and sort them.
protected function computePercent() {
$this->total = 0;
$this->percent = array();
$pointList = $this->dataSet->getPointList();
foreach ($pointList as $point) {
$this->total += $point->getY();
$percent = $this->total == 0 ? 0 : 100 * $point->getY() / $this->total;
array_push($this->percent, array($percent, $point));
// Sort data points
if ($this->config->getSortDataPoint()) {
usort($this->percent, array("PieChart", "sortPie"));
* Creates the pie chart image.
protected function createImage() {
parent::createImage();
// Get graphical obects
$img = $this->plot->getImg();
$palette = $this->plot->getPalette();
$primitive = $this->plot->getPrimitive();
// Legend box
$primitive->outlinedBox($graphArea->x1, $graphArea->y1, $graphArea->x2, $graphArea->y2, $palette->axisColor[0], $palette->axisColor[1]);
// Aqua-like background
for ($i = $graphArea->y1 + 2; $i < $graphArea->y2 - 1; $i++) {
$color = $palette->backgroundColor[($i + 3) % 4];
$primitive->line($graphArea->x1 + 2, $i, $graphArea->x2 - 2, $i, $color);
* Renders the caption.
protected function printCaption() {
// Create a list of labels
$labelList = array();
foreach($this->percent as $percent) {
list($percent, $point) = $percent;
$label = $point->getX();
array_push($labelList, $label);
// Create the caption
$caption = new Caption();
$caption->setPlot($this->plot);
$caption->setLabelList($labelList);
$pieColorSet = $palette->pieColorSet;
$caption->setColorSet($pieColorSet);
// Render the caption
$caption->render();
* Draw a 2D disc.
* @param integer Center coordinate (y)
* @param array Colors for each portion
* @param bitfield Drawing mode
protected function drawDisc($cy, $colorArray, $mode) {
$i = 0;
$oldAngle = 0;
$percentTotal = 0;
foreach ($this->percent as $a) {
list ($percent, $point) = $a;
// If value is null, don't draw this arc
if ($percent <= 0) {
continue;
$color = $colorArray[$i % count($colorArray)];
$percentTotal += $percent;
$newAngle = $percentTotal * 360 / 100;
// imagefilledarc doesn't like null values (#1)
if ($newAngle - $oldAngle >= 1) {
imagefilledarc($img, $this->pieCenterX, $cy, $this->pieWidth, $this->pieHeight, $oldAngle, $newAngle, $color->getColor($img), $mode);
$oldAngle = $newAngle;
$i++;
* Print the percentage text.
protected function drawPercent() {
$text = $this->plot->getText();
$angle1 = 0;
$percentTotal = 0;
// If value is null, the arc isn't drawn, no need to display percent
continue;
$angle2 = $percentTotal * 2 * M_PI / 100;
$angle = $angle1 + ($angle2 - $angle1) / 2;
$label = number_format($percent) . "%";
$x = cos($angle) * ($this->pieWidth + 35) / 2 + $this->pieCenterX;
$y = sin($angle) * ($this->pieHeight + 35) / 2 + $this->pieCenterY;
$text->printText($img, $x, $y, $this->plot->getTextColor(), $label, $text->fontCondensed, $text->HORIZONTAL_CENTER_ALIGN | $text->VERTICAL_CENTER_ALIGN);
$angle1 = $angle2;
* Print the pie chart.
protected function printPie() {
// Get the pie color set
$pieColorSet->reset();
// Silhouette
for ($cy = $this->pieCenterY + $this->pieDepth / 2; $cy >= $this->pieCenterY - $this->pieDepth / 2; $cy--) {
$this->drawDisc($cy, $palette->pieColorSet->shadowColorList, IMG_ARC_EDGED);
// Top
$this->drawDisc($this->pieCenterY - $this->pieDepth / 2, $palette->pieColorSet->colorList, IMG_ARC_PIE);
// Top Outline
if ($this->config->getShowPointCaption()) {
$this->drawPercent();
* Render the chart image.
* @param string name of the file to render the image to (optional)
public function render($fileName = null) {
$this->computePercent();
$this->computeLayout();
$this->createImage();
$this->plot->printLogo();
$this->plot->printTitle();
$this->printPie();
$this->printCaption();
$this->plot->render($fileName);
Here is my modified file:
`<?php
* Pie chart.
($v1[0] > $v2[0] ? -1 : 1);
$this->total = 0;
// Sort data points
// Legend box
$caption->render();
* Draw a 2D disc.
$i = 0;
$oldAngle = 0;
$percentTotal = 0;
continue;
$i++;
$angle1 = 0;
$percentTotal = 0;
continue;
$angle1 = $angle2;
// Silhouette
// Top
// Top Outline
$this->printPie();
The initial error was on line 67, specifically the "return" statement:
1;
I changed it to this, per Gemini's recommendation:
Now I'm seeing this in the php-fpm.log:
WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "NOTICE: PHP message: PHP Fatal error: Uncaught Error: Call to a member function getPalette() on null in /usr/share/grommunio-archive/archive/model/stat/chart.php:14"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "Stack trace:"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#0 /usr/share/grommunio-archive/archive/controller/stat/graph.php(28): ModelStatChart->lineChartHamSpam()"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#1 /usr/share/grommunio-archive/archive/system/front.php(36): ControllerStatGraph->index()"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#2 /usr/share/grommunio-archive/archive/system/front.php(14): Front->execute()"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#3 /usr/share/grommunio-archive/archive/index.php(114): Front->dispatch()"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#4 {main}"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: " thrown in /usr/share/grommunio-archive/archive/model/stat/chart.php on line 14"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19252 said into stderr: "NOTICE: PHP message: PHP Fatal error: Uncaught Error: Call to a member function getPalette() on null in /usr/share/grommunio-archive/archive/model/stat/chart.php:14"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19252 said into stderr: "Stack trace:"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19252 said into stderr: "#0 /usr/share/grommunio-archive/archive/controller/stat/graph.php(28): ModelStatChart->lineChartHamSpam()"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19252 said into stderr: "#1 /usr/share/grommunio-archive/archive/system/front.php(36): ControllerStatGraph->index()"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19252 said into stderr: "#2 /usr/share/grommunio-archive/archive/system/front.php(14): Front->execute()"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19252 said into stderr: "#3 /usr/share/grommunio-archive/archive/index.php(114): Front->dispatch()"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19252 said into stderr: "#4 {main}"
[27-Jan-2026 09:32:12] WARNING: [pool grommunio-archive-pool] child 19252 said into stderr: " thrown in /usr/share/grommunio-archive/archive/model/stat/chart.php on line 14"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19254 said into stderr: "NOTICE: PHP message: PHP Fatal error: Uncaught Error: Call to a member function getPalette() on null in /usr/share/grommunio-archive/archive/model/stat/chart.php:14"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19254 said into stderr: "Stack trace:"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19254 said into stderr: "#0 /usr/share/grommunio-archive/archive/controller/stat/graph.php(28): ModelStatChart->lineChartHamSpam()"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19254 said into stderr: "#1 /usr/share/grommunio-archive/archive/system/front.php(36): ControllerStatGraph->index()"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19254 said into stderr: "#2 /usr/share/grommunio-archive/archive/system/front.php(14): Front->execute()"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19254 said into stderr: "#3 /usr/share/grommunio-archive/archive/index.php(114): Front->dispatch()"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19254 said into stderr: "#4 {main}"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19254 said into stderr: " thrown in /usr/share/grommunio-archive/archive/model/stat/chart.php on line 14"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19251 said into stderr: "NOTICE: PHP message: PHP Fatal error: Uncaught Error: Call to a member function getPalette() on null in /usr/share/grommunio-archive/archive/model/stat/chart.php:14"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19251 said into stderr: "Stack trace:"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19251 said into stderr: "#0 /usr/share/grommunio-archive/archive/controller/stat/graph.php(28): ModelStatChart->lineChartHamSpam()"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19251 said into stderr: "#1 /usr/share/grommunio-archive/archive/system/front.php(36): ControllerStatGraph->index()"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19251 said into stderr: "#2 /usr/share/grommunio-archive/archive/system/front.php(14): Front->execute()"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19251 said into stderr: "#3 /usr/share/grommunio-archive/archive/index.php(114): Front->dispatch()"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19251 said into stderr: "#4 {main}"
[27-Jan-2026 09:32:16] WARNING: [pool grommunio-archive-pool] child 19251 said into stderr: " thrown in /usr/share/grommunio-archive/archive/model/stat/chart.php on line 14"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19253 said into stderr: "NOTICE: PHP message: PHP Fatal error: Uncaught Error: Call to a member function getPalette() on null in /usr/share/grommunio-archive/archive/model/stat/chart.php:14"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19253 said into stderr: "Stack trace:"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19253 said into stderr: "#0 /usr/share/grommunio-archive/archive/controller/stat/graph.php(28): ModelStatChart->lineChartHamSpam()"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19253 said into stderr: "#1 /usr/share/grommunio-archive/archive/system/front.php(36): ControllerStatGraph->index()"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19253 said into stderr: "#2 /usr/share/grommunio-archive/archive/system/front.php(14): Front->execute()"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19253 said into stderr: "#3 /usr/share/grommunio-archive/archive/index.php(114): Front->dispatch()"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19253 said into stderr: "#4 {main}"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19253 said into stderr: " thrown in /usr/share/grommunio-archive/archive/model/stat/chart.php on line 14"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "NOTICE: PHP message: PHP Fatal error: Uncaught Error: Call to a member function getPalette() on null in /usr/share/grommunio-archive/archive/model/stat/chart.php:14"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "Stack trace:"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#0 /usr/share/grommunio-archive/archive/controller/stat/graph.php(28): ModelStatChart->lineChartHamSpam()"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#1 /usr/share/grommunio-archive/archive/system/front.php(36): ControllerStatGraph->index()"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#2 /usr/share/grommunio-archive/archive/system/front.php(14): Front->execute()"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#3 /usr/share/grommunio-archive/archive/index.php(114): Front->dispatch()"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: "#4 {main}"
[27-Jan-2026 09:32:18] WARNING: [pool grommunio-archive-pool] child 19250 said into stderr: " thrown in /usr/share/grommunio-archive/archive/model/stat/chart.php on line 14"
I'm suspecting that maybe I shouldn't have installed PHP8 by default and should downgrade to PHP7, but I'll defer to your recommendations.
