grommunio:~ # journalctl -f
Mär 30 19:21:47 grommunio systemd[1]: Started Session 3 of User root.
Mär 30 19:21:47 grommunio sshd[2022]: pam_unix(sshd:session): session opened for user root by (uid=0)
Mär 30 19:21:55 grommunio systemd[1]: systemd-timedated.service: Deactivated successfully.
Mär 30 19:22:05 grommunio rspamd[1605]: (controller) <37h8g3>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for list.dnswl.org while 'no records with this name' was expected when querying for '1.0.0.127.list.dnswl.org'(likely DNS spoofing or BL internal issues)
Mär 30 19:22:06 grommunio rspamd[1605]: (controller) <qwmpfs>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for score.senderscore.com while 'no records with this name' was expected when querying for '1.0.0.127.score.senderscore.com'(likely DNS spoofing or BL internal issues)
Mär 30 19:22:15 grommunio sshd[2079]: Accepted keyboard-interactive/pam for root from 192.168.1.185 port 49297 ssh2
Mär 30 19:22:16 grommunio systemd-logind[668]: New session 5 of user root.
Mär 30 19:22:16 grommunio systemd[1]: Started Session 5 of User root.
Mär 30 19:22:16 grommunio sshd[2079]: pam_unix(sshd:session): session opened for user root by (uid=0)
Mär 30 19:22:22 grommunio rspamd[1605]: (controller) <q6ecuh>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for dwl.dnswl.org while 'no records with this name' was expected when querying for '1Cjg2PZ_uaUpZXxbah.dwl.dnswl.org'(likely DNS spoofing or BL internal issues)
Mär 30 19:23:11 grommunio rspamd[1605]: (controller) <qwmpfs>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for score.senderscore.com while 'no records with this name' was expected when querying for '1.0.0.127.score.senderscore.com'(likely DNS spoofing or BL internal issues)
Mär 30 19:23:11 grommunio rspamd[1605]: (controller) <qwmpfs>; monitored; rspamd_monitored_propagate_error: invalid return on resolving score.senderscore.com, disable object
Mär 30 19:23:11 grommunio rspamd[1605]: (controller) <es64mg>; cfg; rspamd_worker_monitored_on_change: broadcast monitored update for qwmpfsngmy3arkm1q45o4oynd78xdhz: dead
Mär 30 19:23:11 grommunio rspamd[1607]: (normal) <es64mg>; cfg; rspamd_worker_monitored_handler: updated monitored status for qwmpfsngmy3arkm1q45o4oynd78xdhz: dead
Mär 30 19:23:11 grommunio rspamd[1606]: (normal) <es64mg>; cfg; rspamd_worker_monitored_handler: updated monitored status for qwmpfsngmy3arkm1q45o4oynd78xdhz: dead
Mär 30 19:23:33 grommunio rspamd[1605]: (controller) <37h8g3>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for list.dnswl.org while 'no records with this name' was expected when querying for '1.0.0.127.list.dnswl.org'(likely DNS spoofing or BL internal issues)
Mär 30 19:23:33 grommunio rspamd[1605]: (controller) <37h8g3>; monitored; rspamd_monitored_propagate_error: invalid return on resolving list.dnswl.org, disable object
Mär 30 19:23:33 grommunio rspamd[1605]: (controller) <es64mg>; cfg; rspamd_worker_monitored_on_change: broadcast monitored update for 37h8g3acpfzcwtw3tqerf3g1jydxfjw: dead
Mär 30 19:23:33 grommunio rspamd[1607]: (normal) <es64mg>; cfg; rspamd_worker_monitored_handler: updated monitored status for 37h8g3acpfzcwtw3tqerf3g1jydxfjw: dead
Mär 30 19:23:33 grommunio rspamd[1606]: (normal) <es64mg>; cfg; rspamd_worker_monitored_handler: updated monitored status for 37h8g3acpfzcwtw3tqerf3g1jydxfjw: dead
Mär 30 19:23:55 grommunio rspamd[1605]: (controller) <q6ecuh>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for dwl.dnswl.org while 'no records with this name' was expected when querying for 'lJdcrsmNfsWoPN-uV0ey.dwl.dnswl.org'(likely DNS spoofing or BL internal issues)
Mär 30 19:23:55 grommunio rspamd[1605]: (controller) <q6ecuh>; monitored; rspamd_monitored_propagate_error: invalid return on resolving dwl.dnswl.org, disable object
Mär 30 19:23:55 grommunio rspamd[1605]: (controller) <es64mg>; cfg; rspamd_worker_monitored_on_change: broadcast monitored update for q6ecuhoj4jaahipt36syabjf9j4gn3b: dead
Mär 30 19:23:55 grommunio rspamd[1606]: (normal) <es64mg>; cfg; rspamd_worker_monitored_handler: updated monitored status for q6ecuhoj4jaahipt36syabjf9j4gn3b: dead
Mär 30 19:23:55 grommunio rspamd[1607]: (normal) <es64mg>; cfg; rspamd_worker_monitored_handler: updated monitored status for q6ecuhoj4jaahipt36syabjf9j4gn3b: dead
Mär 30 19:25:01 grommunio systemd[1]: Created slice User Slice of UID 477.
Mär 30 19:25:01 grommunio systemd[1]: Starting User Runtime Directory /run/user/477...
Mär 30 19:25:01 grommunio systemd[1]: Finished User Runtime Directory /run/user/477.
Mär 30 19:25:01 grommunio systemd[1]: Starting User Manager for UID 477...
Mär 30 19:25:01 grommunio (systemd)[2833]: pam_unix(systemd-user:session): session opened for user groarchive by (uid=0)
Mär 30 19:25:01 grommunio systemd[2833]: Queued start job for default target Main User Target.
Mär 30 19:25:01 grommunio systemd[2833]: Created slice User Application Slice.
Mär 30 19:25:01 grommunio systemd[2833]: Started Daily Cleanup of User's Temporary Directories.
Mär 30 19:25:01 grommunio systemd[2833]: Reached target Paths.
Mär 30 19:25:01 grommunio systemd[2833]: Reached target Timers.
Mär 30 19:25:01 grommunio systemd[2833]: Starting D-Bus User Message Bus Socket...
Mär 30 19:25:01 grommunio systemd[2833]: Starting Create User Files and Directories...
Mär 30 19:25:01 grommunio systemd[2833]: Finished Create User Files and Directories.
Mär 30 19:25:01 grommunio systemd[2833]: Listening on D-Bus User Message Bus Socket.
Mär 30 19:25:01 grommunio systemd[2833]: Reached target Sockets.
Mär 30 19:25:01 grommunio systemd[2833]: Reached target Basic System.
Mär 30 19:25:01 grommunio systemd[2833]: Reached target Main User Target.
Mär 30 19:25:01 grommunio systemd[2833]: Startup finished in 337ms.
Mär 30 19:25:01 grommunio systemd[1]: Started User Manager for UID 477.
Mär 30 19:25:01 grommunio systemd[1]: Started Session c1 of User groarchive.
Mär 30 19:25:01 grommunio systemd[1]: Started Session c2 of User groarchive.
Mär 30 19:25:01 grommunio cron[2830]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
Mär 30 19:25:01 grommunio CRON[2846]: (groarchive) CMD (/usr/bin/find /usr/share/grommunio-archive/archive/tmp -type f -name i.* -exec rm -f {} \đ
Mär 30 19:25:01 grommunio cron[2829]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
Mär 30 19:25:01 grommunio CRON[2830]: (groarchive) CMDEND (/usr/bin/find /usr/share/grommunio-archive/archive/tmp -type f -name i.* -exec rm -f {} \đ
Mär 30 19:25:01 grommunio CRON[2847]: (groarchive) CMD (/usr/bin/find /var/lib/grommunio-archive/error -type f | wc -l > /var/lib/grommunio-archive/stat/error)
Mär 30 19:25:01 grommunio CRON[2830]: pam_unix(crond:session): session closed for user groarchive
Mär 30 19:25:01 grommunio systemd[1]: session-c1.scope: Deactivated successfully.
Mär 30 19:25:01 grommunio CRON[2829]: (groarchive) CMDEND (/usr/bin/find /var/lib/grommunio-archive/error -type f | wc -l > /var/lib/grommunio-archive/stat/error)
Mär 30 19:25:01 grommunio CRON[2829]: pam_unix(crond:session): session closed for user groarchive
Mär 30 19:25:01 grommunio systemd[1]: session-c2.scope: Deactivated successfully.
Mär 30 19:25:11 grommunio systemd[1]: Stopping User Manager for UID 477...
Mär 30 19:25:12 grommunio systemd[2833]: Activating special unit Exit the Session...
Mär 30 19:25:12 grommunio systemd[2833]: Stopped target Main User Target.
Mär 30 19:25:12 grommunio systemd[2833]: Stopped target Basic System.
Mär 30 19:25:12 grommunio systemd[2833]: Stopped target Paths.
Mär 30 19:25:12 grommunio systemd[2833]: Stopped target Sockets.
Mär 30 19:25:12 grommunio systemd[2833]: Stopped target Timers.
Mär 30 19:25:12 grommunio systemd[2833]: Stopped Daily Cleanup of User's Temporary Directories.
Mär 30 19:25:12 grommunio systemd[2833]: Closed D-Bus User Message Bus Socket.
Mär 30 19:25:12 grommunio systemd[2833]: Stopped Create User Files and Directories.
Mär 30 19:25:12 grommunio systemd[2833]: Removed slice User Application Slice.
Mär 30 19:25:12 grommunio systemd[2833]: Reached target Shutdown.
Mär 30 19:25:12 grommunio systemd[2833]: Finished Exit the Session.
Mär 30 19:25:12 grommunio systemd[2833]: Reached target Exit the Session.
Mär 30 19:25:12 grommunio systemd[1]: user@477.service: Deactivated successfully.
Mär 30 19:25:12 grommunio systemd[1]: Stopped User Manager for UID 477.
Mär 30 19:25:12 grommunio systemd[1]: Stopping User Runtime Directory /run/user/477...
Mär 30 19:25:12 grommunio systemd[1]: run-user-477.mount: Deactivated successfully.
Mär 30 19:25:12 grommunio systemd[1]: user-runtime-dir@477.service: Deactivated successfully.
Mär 30 19:25:12 grommunio systemd[1]: Stopped User Runtime Directory /run/user/477.
Mär 30 19:25:12 grommunio systemd[1]: Removed slice User Slice of UID 477.
Mär 30 19:25:29 grommunio systemd[1]: Started Run grommunio Files cron-job every 15 minutes.
Mär 30 19:25:32 grommunio systemd[1]: grommunio-files-cron.service: Deactivated successfully.
Mär 30 19:25:32 grommunio systemd[1]: grommunio-files-cron.service: Consumed 1.434s CPU time.
Mär 30 19:25:42 grommunio chronyd[1446]: Selected source 193.203.3.171 (2.opensuse.pool.ntp.org)
Mär 30 19:25:42 grommunio rspamd[1605]: (controller) <37h8g3>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for list.dnswl.org while 'no records with this name' was expected when querying for '1.0.0.127.list.dnswl.org'(likely DNS spoofing or BL internal issues)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <9oqwi6>; map; http_map_finish: data is not modified for server sa-update.surbl.org (http://sa-update.surbl.org/rspamd/surbl-hashbl-map.inc), next check at Mon, 30 Mar 2026 17:31:21 GMT (timer based)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <orfb3c>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/disabled_rbls.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <bwak36>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/phishing_whitelist.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <bzbmok>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/dmarc_whitelist_new.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <fbh833>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/surbl-whitelist.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <96bjhn>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/mid.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <adkqb9>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/spf_dkim_whitelist.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <4x4rch>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/redirectors.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <5h7xm3>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/freemail/free.txt.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <srz3gm>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/redirectors.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <ie1d6u>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/mime_types.inc.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:21 grommunio rspamd[1605]: (controller) <5kwsjw>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/freemail/disposable.txt.zst), next check at Mon, 30 Mar 2026 17:31:21 GMT (http cache based: Mon, 30 Mar 2026 21:26:21 GMT)
Mär 30 19:26:52 grommunio rspamd[1605]: (controller) <qwmpfs>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for score.senderscore.com while 'no records with this name' was expected when querying for '1.0.0.127.score.senderscore.com'(likely DNS spoofing or BL internal issues)
Mär 30 19:27:02 grommunio rspamd[1605]: (controller) <q6ecuh>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for dwl.dnswl.org while 'no records with this name' was expected when querying for '1Go9QxmCQmS2k7ZDGU28fN7cYNm.dwl.dnswl.org'(likely DNS spoofing or BL internal issues)
Mär 30 19:27:36 grommunio systemd[2030]: Created slice User Background Tasks Slice.
Mär 30 19:27:36 grommunio systemd[2030]: Starting Cleanup of User's Temporary Files and Directories...
Mär 30 19:27:36 grommunio systemd[2030]: Finished Cleanup of User's Temporary Files and Directories.
Mär 30 19:29:47 grommunio rspamd[1605]: (controller) <37h8g3>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for list.dnswl.org while 'no records with this name' was expected when querying for '1.0.0.127.list.dnswl.org'(likely DNS spoofing or BL internal issues)
Mär 30 19:30:02 grommunio systemd[1]: Created slice User Slice of UID 477.
Mär 30 19:30:02 grommunio systemd[1]: Starting User Runtime Directory /run/user/477...
Mär 30 19:30:02 grommunio systemd[1]: Finished User Runtime Directory /run/user/477.
Mär 30 19:30:02 grommunio systemd[1]: Starting User Manager for UID 477...
Mär 30 19:30:02 grommunio (systemd)[3713]: pam_unix(systemd-user:session): session opened for user groarchive by (uid=0)
Mär 30 19:30:02 grommunio systemd[3713]: Queued start job for default target Main User Target.
Mär 30 19:30:02 grommunio systemd[3713]: Created slice User Application Slice.
Mär 30 19:30:02 grommunio systemd[3713]: Started Daily Cleanup of User's Temporary Directories.
Mär 30 19:30:02 grommunio systemd[3713]: Reached target Paths.
Mär 30 19:30:02 grommunio systemd[3713]: Reached target Timers.
Mär 30 19:30:03 grommunio systemd[3713]: Starting D-Bus User Message Bus Socket...
Mär 30 19:30:03 grommunio systemd[3713]: Starting Create User Files and Directories...
Mär 30 19:30:03 grommunio systemd[3713]: Finished Create User Files and Directories.
Mär 30 19:30:03 grommunio systemd[3713]: Listening on D-Bus User Message Bus Socket.
Mär 30 19:30:03 grommunio systemd[3713]: Reached target Sockets.
Mär 30 19:30:03 grommunio systemd[3713]: Reached target Basic System.
Mär 30 19:30:03 grommunio systemd[1]: Started User Manager for UID 477.
Mär 30 19:30:03 grommunio systemd[3713]: Reached target Main User Target.
Mär 30 19:30:03 grommunio systemd[3713]: Startup finished in 659ms.
Mär 30 19:30:03 grommunio systemd[1]: Started Session c3 of User groarchive.
Mär 30 19:30:03 grommunio systemd[1]: Started Session c4 of User groarchive.
Mär 30 19:30:03 grommunio systemd[1]: Started Session c5 of User groarchive.
Mär 30 19:30:03 grommunio systemd[1]: Started Session c6 of User groarchive.
Mär 30 19:30:03 grommunio cron[3690]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
Mär 30 19:30:03 grommunio CRON[3727]: (groarchive) CMD (/usr/bin/find /var/lib/grommunio-archive/error -type f | wc -l > /var/lib/grommunio-archive/stat/error)
Mär 30 19:30:03 grommunio CRON[3690]: (groarchive) CMDEND (/usr/bin/find /var/lib/grommunio-archive/error -type f | wc -l > /var/lib/grommunio-archive/stat/error)
Mär 30 19:30:03 grommunio cron[3691]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
Mär 30 19:30:03 grommunio CRON[3730]: (groarchive) CMD (/usr/bin/find /usr/share/grommunio-archive/archive/tmp -type f -name i.* -exec rm -f {} \đ
Mär 30 19:30:03 grommunio CRON[3691]: (groarchive) CMDEND (/usr/bin/find /usr/share/grommunio-archive/archive/tmp -type f -name i.* -exec rm -f {} \đ
Mär 30 19:30:03 grommunio cron[3693]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
Mär 30 19:30:03 grommunio CRON[3731]: (groarchive) CMD (/usr/bin/indexer --config /etc/sphinx/sphinx.conf --quiet note1 --rotate)
Mär 30 19:30:03 grommunio cron[3694]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
Mär 30 19:30:03 grommunio systemd[1]: session-c3.scope: Deactivated successfully.
Mär 30 19:30:03 grommunio CRON[3690]: pam_unix(crond:session): session closed for user groarchive
Mär 30 19:30:03 grommunio CRON[3733]: (groarchive) CMD (/usr/bin/indexer --config /etc/sphinx/sphinx.conf --quiet tag1 --rotate)
Mär 30 19:30:03 grommunio CRON[3691]: pam_unix(crond:session): session closed for user groarchive
Mär 30 19:30:03 grommunio systemd[1]: session-c4.scope: Deactivated successfully.
Mär 30 19:30:03 grommunio searchd[1421]: caught SIGHUP (seamless=1, in queue=1)
Mär 30 19:30:03 grommunio CRON[3694]: (groarchive) CMDEND (/usr/bin/indexer --config /etc/sphinx/sphinx.conf --quiet tag1 --rotate)
Mär 30 19:30:03 grommunio searchd[1421]: caught SIGHUP (seamless=1, in queue=2)
Mär 30 19:30:03 grommunio CRON[3693]: (groarchive) CMDEND (/usr/bin/indexer --config /etc/sphinx/sphinx.conf --quiet note1 --rotate)
Mär 30 19:30:03 grommunio searchd[1421]: rotating index 'tag1': started
Mär 30 19:30:03 grommunio CRON[3694]: pam_unix(crond:session): session closed for user groarchive
Mär 30 19:30:03 grommunio CRON[3693]: pam_unix(crond:session): session closed for user groarchive
Mär 30 19:30:03 grommunio systemd[1]: session-c6.scope: Deactivated successfully.
Mär 30 19:30:03 grommunio searchd[1421]: WARNING: binlog: failed to unlink /var/lib/grommunio-archive/sphinx//binlog.001: No such file or directory (remove it manually)
Mär 30 19:30:03 grommunio searchd[1421]: rotating index 'tag1': success
Mär 30 19:30:03 grommunio searchd[1421]: rotating index: all indexes done
Mär 30 19:30:03 grommunio systemd[1]: session-c5.scope: Deactivated successfully.
Mär 30 19:30:04 grommunio searchd[1421]: rotating index 'note1': started
Mär 30 19:30:04 grommunio searchd[1421]: rotating index 'note1': success
Mär 30 19:30:04 grommunio searchd[1421]: rotating index: all indexes done
Mär 30 19:30:14 grommunio systemd[1]: Stopping User Manager for UID 477...
Mär 30 19:30:14 grommunio systemd[3713]: Activating special unit Exit the Session...
Mär 30 19:30:14 grommunio systemd[3713]: Stopped target Main User Target.
Mär 30 19:30:14 grommunio systemd[3713]: Stopped target Basic System.
Mär 30 19:30:14 grommunio systemd[3713]: Stopped target Paths.
Mär 30 19:30:14 grommunio systemd[3713]: Stopped target Sockets.
Mär 30 19:30:14 grommunio systemd[3713]: Stopped target Timers.
Mär 30 19:30:14 grommunio systemd[3713]: Stopped Daily Cleanup of User's Temporary Directories.
Mär 30 19:30:14 grommunio systemd[3713]: Closed D-Bus User Message Bus Socket.
Mär 30 19:30:14 grommunio systemd[3713]: Stopped Create User Files and Directories.
Mär 30 19:30:14 grommunio systemd[3713]: Removed slice User Application Slice.
Mär 30 19:30:14 grommunio systemd[3713]: Reached target Shutdown.
Mär 30 19:30:14 grommunio systemd[3713]: Finished Exit the Session.
Mär 30 19:30:14 grommunio systemd[3713]: Reached target Exit the Session.
Mär 30 19:30:14 grommunio systemd[1]: user@477.service: Deactivated successfully.
Mär 30 19:30:14 grommunio systemd[1]: Stopped User Manager for UID 477.
Mär 30 19:30:14 grommunio systemd[1]: Stopping User Runtime Directory /run/user/477...
Mär 30 19:30:14 grommunio systemd[1]: run-user-477.mount: Deactivated successfully.
Mär 30 19:30:14 grommunio systemd[1]: user-runtime-dir@477.service: Deactivated successfully.
Mär 30 19:30:14 grommunio systemd[1]: Stopped User Runtime Directory /run/user/477.
Mär 30 19:30:14 grommunio systemd[1]: Removed slice User Slice of UID 477.
Mär 30 19:30:14 grommunio systemd[1]: user-477.slice: Consumed 1.206s CPU time.
Mär 30 19:31:19 grommunio rspamd[1605]: (controller) <qwmpfs>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for score.senderscore.com while 'no records with this name' was expected when querying for '1.0.0.127.score.senderscore.com'(likely DNS spoofing or BL internal issues)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <9oqwi6>; map; http_map_finish: data is not modified for server sa-update.surbl.org (http://sa-update.surbl.org/rspamd/surbl-hashbl-map.inc), next check at Mon, 30 Mar 2026 17:36:21 GMT (timer based)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <srz3gm>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/redirectors.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <5h7xm3>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/freemail/free.txt.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <96bjhn>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/mid.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <fbh833>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/surbl-whitelist.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <4x4rch>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/redirectors.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <orfb3c>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/disabled_rbls.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <adkqb9>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/spf_dkim_whitelist.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <5kwsjw>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/freemail/disposable.txt.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <bwak36>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/phishing_whitelist.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <ie1d6u>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/mime_types.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:21 grommunio rspamd[1605]: (controller) <bzbmok>; map; http_map_finish: data is not modified for server maps.rspamd.com (https://maps.rspamd.com/rspamd/dmarc_whitelist_new.inc.zst), next check at Mon, 30 Mar 2026 17:36:21 GMT (http cache based: Mon, 30 Mar 2026 21:31:21 GMT)
Mär 30 19:31:29 grommunio systemd[1]: Started Run grommunio Files cron-job every 15 minutes.
Mär 30 19:31:31 grommunio systemd[1]: grommunio-files-cron.service: Deactivated successfully.
Mär 30 19:31:31 grommunio systemd[1]: grommunio-files-cron.service: Consumed 1.354s CPU time.
