I had some issues with one of the previous upgrades ( a while back) and that was a fun learning experience, build a second mailserver, moved user from server a to server b, getting the DKIM right again, resetting al the SPAM settings et al.
Yet, the issue I had after the upgrade still remains,.. I've got 2 users that generate a lot of grommunio-sync errors.
29/04/2026 09:51:49 [ 4584] [ INFO] [serge.***********@*****.nl] cmd='Ping' memory='5.59 MiB/6.00 MiB' time='180.63s' devType='Outlook' devId='a62554cd8c9245d6a34b2a31f4c25151' getUser='*****.nl\serge.***********@*****.nl' from='40.99.214.125' idle='180s' version='2.4.8.483c521' method='POST' httpcode='200'
29/04/2026 10:55:20 [21820] [ WARN] [#serge.***********@*****.nl] IP: 40.99.214.125 failed to authenticate user '*****.nl\serge.***********@*****.nl'
29/04/2026 10:55:20 [21820] [ INFO] [#serge.***********@*****.nl] cmd='Options' memory='2.28 MiB/6.00 MiB' time='0.01s' devType='Outlook' devId='a62554cd8c9245d6a34b2a31f4c25151' getUser='*****.nl\serge.***********@*****.nl' from='40.99.214.125' idle='0s' version='2.4.8.483c521' method='OPTIONS' httpcode='401'
This also generates issues in the administrative 'mobile devices' view.
I've deleted the associated devices from the users, and instructed them to remove their configured account(s) from their phone(s), unfoirtunately when they (re)create their account the issue also returns. Do you guys have any thoughts about this ( yes unfortunately they -still- use outlook on their phones, but it also happens with a 'real' activesync account).
When the mobile device admin view is working, I can see that teh devices for those uses do sync (the users themselves don't complain about it, but I would like to get rid of the errors)
versions;
grommunio-admin-api 1.18.8.m31adda4 lp156.11.1
grommunio-admin-common 50.10f1afb lp156.51.1
grommunio-admin-web 5.0.0.28.19b1c07 lp156.169.1
grommunio-antispam 4.0.1 lp156.4.1
grommunio-common 29.8 lp156.13.1
grommunio-cui 1.1.3.b0091e0 lp156.6.1
grommunio-dav 1.6.24.84942ef lp156.1.1
grommunio-dbconf 1.1.2.4bbae9a lp156.15.1
grommunio-error-pages 1.0.10.bb2df37 lp156.31.1
grommunio-imapsync 2.314 lp156.1.1
grommunio-index 1.5.0.gb0a01b9 lp156.2.1
grommunio-release 2025.1.2 lp156.8.1
grommunio-setup 1.1.16.46f2af3 lp156.73.1
grommunio-sync 2.4.8.483c521 lp156.23.1
grommunio-web 3.17.271.gce4f0824d lp156.458.1
gromox 3.6.55.mab2f038 lp156.40.1
gromox-debuginfo 3.6.55.mab2f038 lp156.40.1
gromox-debugsource 3.6.55.mab2f038 lp156.40.1
grub2-theme-grommunio 1 lp156.21.1
joe 4.6 lp156.2.4
libbfio1 20240414 lp156.1.2
libesedb1 20240420 lp156.3.2
libexmdbpp0 1.11.17.14d8ad1 lp156.308.1
libHX32 4.27 lp156.1.1
libHX43 5.4 lp156.1.1
libolecf1 20240427 lp156.2.2
libpff1 20231205 lp156.2.2
libtinyxml2-10 10.0.0 lp156.2.2
libwmime2 1.0.0 lp156.3.2
mapi-header-php 2.1.15.2966759 lp156.6.1
nginx-module-brotli 1.0.0rc+git9 lp156.1.2
nginx-module-vts 0.2.5 lp156.1.1
patterns-grommunio 1 lp156.10.1
perl-Authen-NTLM 1.09 lp156.1.1
perl-Encode-IMAPUTF7 1.70.0 lp156.1.1
perl-IO-Tee 0.66 lp156.1.1
perl-JSON-WebToken 0.10 lp156.3.1
perl-Mail-IMAPClient 3.43 lp156.1.1
plymouth-theme-grommunio 1 lp156.20.1
python311-mattermostdriver 7.3.2 lp156.19.1
python311-mysqlclient 1.4.6 lp156.3.3
python311-openapi-core 0.13.7 lp156.13.2
python311-openapi-schema-validator 0.1.5 lp156.11.4
python311-openapi-spec-validator 0.2.9 lp156.12.1
python311-parse 1.21.1 lp156.1.1
python311-pyexmdb 1.11.17.14d8ad1 lp156.308.1
python311-systemd 235 lp156.2.2
python311-uwsgi-python3 2.0.31 lp156.1.6
python3-mattermostdriver 7.3.2 lp156.15.2
python3-openapi-core 0.13.7 lp156.8.1
python3-openapi-schema-validator 0.1.5 lp156.11.4
python3-pamela 1.0.0 lp156.4.2
python3-parse 1.15.0 lp156.2.2
python3-pyexmdb 1.11.17.14d8ad1 lp156.308.1
python3-rfc3339-validator 0.1.4 lp156.9.2
systemd-coredump-grommunio 1 lp156.3.1
systemd-presets-branding-grommunio 2024.06 lp156.2.1
system-user-grommunio 10 lp156.6.1
system-user-gromox 9 lp156.6.1
update-alternatives 1.22.18 lp156.5.2
uwsgi 2.0.31 lp156.1.6
Do any of you have any suggestions on where the issue could be located?
-edit- typos
