I've been using Grommunio now for nearly a year I think, and I just can't figure out how the dbconf feature should be configured and how it is 'applied'( to the postfix config for instance).
I get that I should be able to set postfix key=value options in the database that then should be applied to the postfix configuration. That would not only be useful for multi server configurations, but also for having all the necessary modifications in one place, where they should be easy to maintain.
Can somebody maybe explain to me how to set the DKIM option non_smtpd_milter to $smtpd_milter with the dbconf feature?
normally afte4r install I would set this manually with the command
postconf -e 'non_smtpd_milter = $smtpd_milter'
but I guess that should also be possible via the dbconf feature right, but I just can't figure it out based on the documentation.
So any example for a postfix setting with dbconf would be very helpfull.
