Hi All, i just download the last container and try to spin it up ! But the latest version looks to be damaged:
My command under Ubuntu 20.04 server
Maybe someone can help ?!?
My output:
exadmin@S-PDCN11MAIL01:/data/grommunio$ wget -c https://download.grommunio.com/appliance/grommunio_Appliance.x86_64-latest.tar
--2021-12-06 21:33:18-- https://download.grommunio.com/appliance/grommunio_Appliance.x86_64-latest.tar
Resolving download.grommunio.com (download.grommunio.com)... 116.202.44.227
Connecting to download.grommunio.com (download.grommunio.com)|116.202.44.227|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 643476480 (614M) [application/octet-stream]
Saving to: ‘grommunio_Appliance.x86_64-latest.tar’
grommunio_Appliance.x86_64-latest.tar 100%[========================================================================================================================================>] 613.67M 2.09MB/s in 7m 50s
2021-12-06 21:41:10 (1.31 MB/s) - ‘grommunio_Appliance.x86_64-latest.tar’ saved [643476480/643476480]
exadmin@S-PDCN11MAIL01:/data/grommunio$ sudo docker image import grommunio_Appliance.x86_64-latest.tar grommunio:latest
sha256:ae7c864a02499840b4af6499881efdc0da2d706086abf14992fafcdff7152486
exadmin@S-PDCN11MAIL01:/data/grommunio$ sudo docker run grommunio:latest /bin/bash
docker: Error response from daemon: OCI runtime create failed: container_linux.go:380: starting container process caused: exec: "/bin/bash": stat /bin/bash: no such file or directory: unknown.
ERRO[0000] error waiting for container: context canceled
exadmin@S-PDCN11MAIL01:/data/grommunio$ sudo docker inspect grommunio:latest
"Id": "sha256:ae7c864a02499840b4af6499881efdc0da2d706086abf14992fafcdff7152486",
"RepoTags": [
"grommunio:latest"
"RepoDigests": [],
"Parent": "",
"Comment": "Imported from -",
"Created": "2021-12-06T13:41:45.045138944Z",
"Container": "",
"ContainerConfig": {
"Hostname": "",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": null,
"Cmd": null,
"Image": "",
"Volumes": null,
"WorkingDir": "",
"Entrypoint": null,
"OnBuild": null,
"Labels": null
"DockerVersion": "20.10.10",
"Author": "",
"Config": {
"Hostname": "",
"Domainname": "",
"User": "",
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": null,
"Cmd": null,
"Image": "",
"Volumes": null,
"WorkingDir": "",
"Entrypoint": null,
"OnBuild": null,
"Labels": null
"Architecture": "amd64",
"Os": "linux",
"Size": 643473201,
"VirtualSize": 643473201,
"GraphDriver": {
"Data": {
"MergedDir": "/data/docker/overlay2/53024882e253a1eeb3de366157aa326ed322e6d2cb5227c8285b475bd54b3873/merged",
"UpperDir": "/data/docker/overlay2/53024882e253a1eeb3de366157aa326ed322e6d2cb5227c8285b475bd54b3873/diff",
"WorkDir": "/data/docker/overlay2/53024882e253a1eeb3de366157aa326ed322e6d2cb5227c8285b475bd54b3873/work"
"Name": "overlay2"
"RootFS": {
"Type": "layers",
"Layers": [
"sha256:d895c9fd5d8047b214c64d419d3dd5e483fd7c4310fb5521e38a4c24df3493a7"
"Metadata": {
"LastTagTime": "2021-12-06T21:41:45.074745423+08:00"
