• General
  • [SOLVED] gromox error in /var/log/gromox/sa.log (any idea howto fix)
checking /var/log/gromox/sa.log
a ton of
[data_source]:
Failed to connect to mysql server, reason: Access denied for user 'grommunio'@'localhost' (using password: NO)
this error occurs also after a fresh installation.
any hints how to fix this
    After more investigating and experimenting, it appears that mysql_password value in /etc/gromox/adapter.cfg is not being parsed correctly.
    (https://docs.grommunio.com/man/adaptor.8gx.html) states:
    mysql_password
    Default: (unset)
    However, when looking at (https://github.com/grommunio/gromox/blob/master/tools/adaptor/main.cpp), the way the config file is parsed states (line 78):
    data_source_init(pconfig->get_value("mysql_host"),
    strtol(pconfig->get_value("mysql_port"), nullptr, 0),
    pconfig->get_value("mysql_username"), pconfig->get_value("mysql_passwd"),
    pconfig->get_value("mysql_dbname"));
    Thus when reading the config file, the token it is looking for is mysql_passwd and not mysql_password as the documentation states. I'm opening a github issue about this, as once I made the change the errors disappear:
    (https://github.com/grommunio/gromox/issues/11)
    For the time being, if you edit /etc/gromox/adapter.cfg and change mysql_password to mysql_passwd this should get rid of these errors. Be sure to restart gromox-adapter after making the changes.
    I'm new to Grommunio - only just installed it last night, so please excuse me if I am wrong.
    Thanks @obsidiangroup , i tried your solution and can confirm that this worked for me. No more errors in the sa.log
    Already addressed by gromox-1.2-136-gc7dc2f6b .
      jengelh
      And how we can run update
      Or when wo the next ISO be avail with this fix
      mwilliams
      No problem. I was just trying to figure out why the problem was happening and once I ruled out everything else I started looking through the source code. I actually overlooked it a few times because my brain saw 'mysql_passwd' but it just looked right. Then my last glance of the code, it just popped out at me. I've made the same mistake many times. 'passwd' just looks right.
      23 days later
      noplan changed the title to [solved ]gromox error in /var/log/gromox/sa.log (any idea howto fix) .
      solved with correction of config file
      and later with update
      mwilliams changed the title to [SOLVED] gromox error in /var/log/gromox/sa.log (any idea howto fix) .
