Mir ist aufgefallen, dass der Account im MDM nicht mehr auftaucht. Habe daher auch nochmal den Account auf dem Handy gelöscht und dann neu angelegt. Aber auch danach taucht er im MDM im Web-Interface nicht auf.
Hier ein Auszug des Sync-Log:
29/05/2023 11:30:30 [2248830] [ INFO] [user@domain.tld] MAPIProvider->getEmailAddressFromSearchKey(): fall back to PR_SEARCH_KEY or PR_SENT_REPRESENTING_SEARCH_KEY to resolve user and get email address
29/05/2023 11:30:31 [2248830] [ INFO] [user@domain.tld] MAPIProvider->getEmailAddressFromSearchKey(): fall back to PR_SEARCH_KEY or PR_SENT_REPRESENTING_SEARCH_KEY to resolve user and get email address
29/05/2023 11:30:31 [2248830] [ INFO] [user@domain.tld] cmd='Sync' memory='6.37 MiB/2.00 MiB' time='2.01s' devType='SamsungDevice' devId='sec999d93e34e222' getUser='user@domain.tld' from='192.168.1.2' idle='0s' version='2.0.15.cba7b39-0' method='POST' httpcode='200'
29/05/2023 11:30:32 [2248109] [ INFO] [user@domain.tld] Policy 'devencenabled' not supported by the device, ignoring
29/05/2023 11:30:32 [2248109] [ INFO] [user@domain.tld] Grommunio->getStateFolder(): state folder not set. Use fallback
29/05/2023 11:30:32 [2248109] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1892 mapi_getprops() expects parameter 1 to be resource, bool given (2)
29/05/2023 11:30:32 [2248109] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1893 Trying to access array offset on value of type bool (8)
29/05/2023 11:30:33 [2248109] [ INFO] [user@domain.tld] MAPIProvider->getEmailAddressFromSearchKey(): fall back to PR_SEARCH_KEY or PR_SENT_REPRESENTING_SEARCH_KEY to resolve user and get email address
29/05/2023 11:30:33 [2248109] [ INFO] [user@domain.tld] cmd='Sync' memory='6.19 MiB/2.00 MiB' time='0.95s' devType='SamsungDevice' devId='sec999d93e34e222' getUser='user@domain.tld' from='192.168.1.2' idle='0s' version='2.0.15.cba7b39-0' method='POST' httpcode='200'
29/05/2023 11:30:35 [2248105] [ INFO] [user@domain.tld] Policy 'devencenabled' not supported by the device, ignoring
29/05/2023 11:30:35 [2248105] [ INFO] [user@domain.tld] Grommunio->getStateFolder(): state folder not set. Use fallback
29/05/2023 11:30:35 [2248105] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1892 mapi_getprops() expects parameter 1 to be resource, bool given (2)
29/05/2023 11:30:35 [2248105] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1893 Trying to access array offset on value of type bool (8)
29/05/2023 11:30:35 [2248106] [ INFO] [user@domain.tld] Grommunio->getStateFolder(): state folder not set. Use fallback
29/05/2023 11:30:35 [2248106] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1892 mapi_getprops() expects parameter 1 to be resource, bool given (2)
29/05/2023 11:30:35 [2248106] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1893 Trying to access array offset on value of type bool (8)
29/05/2023 11:30:35 [2248106] [ INFO] [user@domain.tld] SyncCollections->CheckForChanges(): Waiting for store changes... (lifetime 880 seconds)
29/05/2023 11:30:35 [2248104] [ INFO] [user@domain.tld] StatusException: SyncCollections->CheckForChanges(): Timeout forced after 5s from 880s due to other process - code: 3 - file: /usr/share/grommunio-sync/lib/core/synccollections.php:587
29/05/2023 11:30:35 [2248104] [ INFO] [user@domain.tld] cmd='Ping' memory='5.85 MiB/2.00 MiB' time='6.68s' devType='SamsungDevice' devId='sec999d93e34e222' getUser='user@domain.tld' from='192.168.1.2' idle='5s' version='2.0.15.cba7b39-0' method='POST' httpcode='200'
29/05/2023 11:30:36 [2248105] [ INFO] [user@domain.tld] cmd='Sync' memory='6.19 MiB/2.00 MiB' time='1.14s' devType='SamsungDevice' devId='sec999d93e34e222' getUser='user@domain.tld' from='192.168.1.2' idle='0s' version='2.0.15.cba7b39-0' method='POST' httpcode='200'
29/05/2023 11:30:37 [2248103] [ INFO] [user@domain.tld] Policy 'devencenabled' not supported by the device, ignoring
29/05/2023 11:30:37 [2248103] [ INFO] [user@domain.tld] Grommunio->getStateFolder(): state folder not set. Use fallback
29/05/2023 11:30:37 [2248103] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1892 mapi_getprops() expects parameter 1 to be resource, bool given (2)
29/05/2023 11:30:37 [2248103] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1893 Trying to access array offset on value of type bool (8)
29/05/2023 11:30:38 [2248103] [ INFO] [user@domain.tld] cmd='Sync' memory='6.19 MiB/2.00 MiB' time='0.66s' devType='SamsungDevice' devId='sec999d93e34e222' getUser='user@domain.tld' from='192.168.1.2' idle='0s' version='2.0.15.cba7b39-0' method='POST' httpcode='200'
29/05/2023 11:30:38 [2248110] [ INFO] [user@domain.tld] Policy 'devencenabled' not supported by the device, ignoring
29/05/2023 11:30:38 [2248110] [ INFO] [user@domain.tld] Grommunio->getStateFolder(): state folder not set. Use fallback
29/05/2023 11:30:38 [2248110] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1892 mapi_getprops() expects parameter 1 to be resource, bool given (2)
29/05/2023 11:30:38 [2248110] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1893 Trying to access array offset on value of type bool (8)
29/05/2023 11:30:38 [2248831] [ INFO] [user@domain.tld] Grommunio->getStateFolder(): state folder not set. Use fallback
29/05/2023 11:30:38 [2248831] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1892 mapi_getprops() expects parameter 1 to be resource, bool given (2)
29/05/2023 11:30:38 [2248831] [ WARN] [user@domain.tld] /usr/share/grommunio-sync/lib/grommunio/grommunio.php:1893 Trying to access array offset on value of type bool (8)
29/05/2023 11:30:39 [2248831] [ INFO] [user@domain.tld] SyncCollections->CheckForChanges(): Waiting for store changes... (lifetime 880 seconds)
29/05/2023 11:30:39 [2248106] [ INFO] [user@domain.tld] StatusException: SyncCollections->CheckForChanges(): Timeout forced after 4s from 880s due to other process - code: 3 - file: /usr/share/grommunio-sync/lib/core/synccollections.php:587
29/05/2023 11:30:39 [2248106] [ INFO] [user@domain.tld] cmd='Ping' memory='5.85 MiB/2.00 MiB' time='4.75s' devType='SamsungDevice' devId='sec999d93e34e222' getUser='user@domain.tld' from='192.168.1.2' idle='4s' version='2.0.15.cba7b39-0' method='POST' httpcode='200'
29/05/2023 11:30:39 [2248110] [ INFO] [user@domain.tld] cmd='Sync' memory='6.19 MiB/2.00 MiB' time='1.01s' devType='SamsungDevice' devId='sec999d93e34e222' getUser='user@domain.tld' from='192.168.1.2' idle='0s' version='2.0.15.cba7b39-0' method='POST' httpcode='200'
Bin mehr und mehr ratlos....
Die Daten werden aufs Handy übertragen, aber es scheint auch ein Problem mit der Rückübertragugn von Änderungen zu geben, die ich auf dem Handy mache. Aufgefallen ist mir das bei Terminen.
