beim synchronisieren der Kalender (Samsung Android Tablet, verwendet EAS 16.0) sehe ich folgenden Fehler in den Logs (/var/log/grommunio-sync/grommunio-sync-error.log):
28/06/2023 17:01:09 [15093] [ERROR] [XXX] LoopDetection->ProcessLoopDetectionPreviousConnectionFailed(): Command 'Sync' at 28/06/2023 16:57:08 with pid '16887' terminated unexpectedly or is still running.
28/06/2023 17:01:09 [15093] [ERROR] [XXX] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the grommunio dev team.
28/06/2023 17:01:10 [14801] [FATAL] [XXX] Fatal error: /usr/share/grommunio-sync/lib/grommunio/mapiprovider.php:1443 - Uncaught Error: Call to undefined method SyncAppointment::parseDate() in /usr/share/grommunio-sync/lib/grommunio/mapiprovider.php:1443
Stack trace:
#0 /usr/share/grommunio-sync/lib/grommunio/mapiprovider.php(1260): MAPIProvider->setAppointment(Resource id #154, Object(SyncAppointment))
#1 /usr/share/grommunio-sync/lib/grommunio/importer.php(408): MAPIProvider->SetMessage(Resource id #154, Object(SyncAppointment))
#2 /usr/share/grommunio-sync/lib/request/sync.php(1550): ImportChangesICS->ImportMessageChange('U9759e:09000000...', Object(SyncAppointment))
#3 /usr/share/grommunio-sync/lib/request/sync.php(565): Sync->importMessage(Object(SyncParameters), Array, 'Modify', Object(SyncAppointment), false, 'U9759e:09000000...', false, 4)
#4 /usr/share/grommunio-sync/lib/request/requestprocessor.php(98): Sync->Handle(0)
#5 /usr/share/grommunio-sync/index.php(114): RequestProcessor::HandleRequest()
#6 {main}
thrown (1)
Das Gerät zeigt zwar keine Fehlermeldung, aber es werden dadurch offenbar nicht alle Einträge mit dem Server synchronisiert, neu angelegte Test-Einträge erscheinen nicht am Server.
Installed Packages
grommunio-admin-api-1.11.18.4a0603d-lp154.21.1.noarch
grommunio-admin-common-6.cb985db-lp154.9.1.noarch
grommunio-admin-web-2.7.0.9.973f1cc-lp154.9.1.noarch
grommunio-antispam-3.4-lp154.5.1.x86_64
grommunio-common-14.dfc18e0-lp154.13.1.x86_64
grommunio-cui-1.0.249.c3568dd-lp154.17.1.noarch
grommunio-dav-1.3.11.2b59b5d-lp154.1.1.noarch
grommunio-dbconf-1.1.1.da20a46-lp154.10.1.x86_64
grommunio-error-pages-1.0.6.9c50afb-lp154.11.1.noarch
grommunio-imapsync-2.178-lp154.3.1.noarch
grommunio-index-0.1.36.4ebe9ad-lp154.12.1.x86_64
grommunio-release-2022.12.1-lp154.3.1.x86_64
grommunio-setup-1.0.91.5a36fde-lp154.13.1.noarch
grommunio-sync-2.0.15.cba7b39-lp154.25.1.noarch
grommunio-web-3.2.44.682819a-lp154.3.1.noarch
gromox-2.9.18.538f503-lp154.3.1.x86_64
gromox-debuginfo-2.9.18.538f503-lp154.3.1.x86_64
gromox-debugsource-2.9.18.538f503-lp154.3.1.x86_64
grub2-theme-grommunio-1-lp154.11.2.noarch
patterns-grommunio-1-lp154.8.2.x86_64
plymouth-theme-grommunio-1-lp154.11.2.noarch
system-user-grommunio-3-lp154.10.2.noarch
system-user-gromox-2-lp154.13.2.noarch
systemd-presets-branding-grommunio-2022.12-lp154.1.2.noarch
