Hello,
[Edit-1] I did re-install Grommunio and still there's no option to create documents, spread sheets and so on.
[Edit-2] I did look through the grommunio-setup.log and the grommunio-office is installed:
(280/293) Installing: grommunio-office-7.4.1-lp154.4.2.x86_64 [......................................................................................................done]
[Edit-3] There seems to be something wrong wiht ONLYOFFICE. I did add the log below. I see this when I am logged in as the admin.
I did use grommunio.x86_64-latest.install.iso to install Grommunio as a VM in Proxmox.
I did notice that everything seems to work, except for Grommunio-Office. I can't create documents in "Files". Only the text-document option is present.
Are there known issues to this? Is there a command to re-run the installation task of Grommunio-Office?
I think I will re-run the whole installation again, as I don't have the installation log anymore. I did discard it as there are passwords in the log file.
Anyone having this issue too?
Thanks.
Kind regards,
Bouke
{"reqId":"57OM8jPZA29sLplRrTMJ","level":3,"time":"2023-09-11T19:34:08+00:00","remoteAddr":"172.21.99.43","user":"admin","app":"onlyoffice","method":"PUT","url":"/files/index.php/apps/onlyoffice/ajax/settings/address","message":"HealthcheckRequest on check error","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36","version":"25.0.10.1","exception":{"Exception":"GuzzleHttp\\Exception\\ServerException","Message":"Server error:GET https://c1.gigabitjes.nl/office/healthcheckresulted in a502 Bad Gatewayresponse:\n<!DOCTYPE html>\n<html>\n<head>\n\t<link rel=\"stylesheet\" type=\"text/css\" href=\"/_errors/main.css\"/>\n\t<title>grommunio - Err (truncated...)\n","Code":502,"Trace":[{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":69,"function":"create","class":"GuzzleHttp\\Exception\\RequestException","type":"::","args":[["GuzzleHttp\\Psr7\\Request"],"*** sensitive parameters replaced ***",null,[],null]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/promises/src/Promise.php","line":204,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/promises/src/Promise.php","line":153,"function":"callHandler","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":[1,"*** sensitive parameters replaced ***",null]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/promises/src/TaskQueue.php","line":48,"function":"GuzzleHttp\\Promise\\{closure}","class":"GuzzleHttp\\Promise\\Promise","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/promises/src/Promise.php","line":248,"function":"run","class":"GuzzleHttp\\Promise\\TaskQueue","type":"->","args":[true]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/promises/src/Promise.php","line":224,"function":"invokeWaitFn","class":"GuzzleHttp\\Promise\\Promise","type":"->","args":[]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/promises/src/Promise.php","line":269,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->","args":[]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/promises/src/Promise.php","line":226,"function":"invokeWaitList","class":"GuzzleHttp\\Promise\\Promise","type":"->","args":[]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/promises/src/Promise.php","line":62,"function":"waitIfPending","class":"GuzzleHttp\\Promise\\Promise","type":"->","args":[]},{"file":"/usr/share/grommunio-files/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"wait","class":"GuzzleHttp\\Promise\\Promise","type":"->","args":[]},{"file":"/usr/share/grommunio-files/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->","args":["get","https://c1.gigabitjes.nl/office/healthcheck",["/var/lib/grommunio-files/data/files_external/rootcerts.crt",60,[true],["Nextcloud Server Crawler","gzip"],true]]},{"file":"/usr/share/grommunio-files/apps/onlyoffice/lib/documentservice.php","line":374,"function":"get","class":"OC\\Http\\Client\\Client","type":"->","args":["https://c1.gigabitjes.nl/office/healthcheck",[60,[true]]]},{"file":"/usr/share/grommunio-files/apps/onlyoffice/lib/documentservice.php","line":259,"function":"Request","class":"OCA\\Onlyoffice\\DocumentService","type":"->","args":["https://c1.gigabitjes.nl/office/healthcheck"]},{"file":"/usr/share/grommunio-files/apps/onlyoffice/lib/documentservice.php","line":406,"function":"HealthcheckRequest","class":"OCA\\Onlyoffice\\DocumentService","type":"->","args":[]},{"file":"/usr/share/grommunio-files/apps/onlyoffice/controller/settingscontroller.php","line":181,"function":"checkDocServiceUrl","class":"OCA\\Onlyoffice\\DocumentService","type":"->","args":[["OC\\URLGenerator",["OC\\User\\Session"]],["OCA\\Onlyoffice\\Crypt"]]},{"file":"/usr/share/grommunio-files/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"SaveAddress","class":"OCA\\Onlyoffice\\Controller\\SettingsController","type":"->","args":["https://c1.gigabitjes.nl/files/","https://c1.gigabitjes.nl/office/","https://c1.gigabitjes.nl/files/",false,"","",false]},{"file":"/usr/share/grommunio-files/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Onlyoffice\\Controller\\SettingsController"],"saveAddress"]},{"file":"/usr/share/grommunio-files/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Onlyoffice\\Controller\\SettingsController"],"saveAddress"]},{"file":"/usr/share/grommunio-files/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["SettingsController","saveAddress",["OC\\AppFramework\\DependencyInjection\\DIContainer"],["onlyoffice.settings.save_address"]]},{"file":"/usr/share/grommunio-files/lib/base.php","line":1053,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/onlyoffice/ajax/settings/address"]},{"file":"/usr/share/grommunio-files/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/usr/share/grommunio-files/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php","Line":113,"message":"HealthcheckRequest on check error","CustomMessage":"HealthcheckRequest on check error"},"id":"64ff6c017e998"}
