I am trying to install Grommunio in a Docker environment and I keep getting stuck. Perhaps someone can point me in the right direction. I am using Ubuntu 22.04 LTS as a base system. Docker is working fine.
I understand grommunio container installation is split in three containers, db, core and admin.
I followed these instructions: https://github.com/grommunio/gromox-container/tree/master/examples
All three start fine and I can log in. My problem is the admin web interface can't seem to connect to core. I found this in the admin log:
examples-admin-1 | [admin] [WARNING] (flask.app) GET /api/v1/system/antispam/stat? from 192.168.178.51 -> 503 '{"message":"Failed to connect to antispam"}\n'
examples-admin-1 | [admin] System has not been booted with systemd as init system (PID 1). Can't operate.
examples-admin-1 | [admin] Failed to connect to bus: Host is down
examples-admin-1 | [admin] [ERROR] (flask.app) Traceback (most recent call last):
examples-admin-1 | [admin] File "/usr/lib/python3.6/site-packages/flask/app.py", line 1838, in full_dispatch_request
examples-admin-1 | [admin] rv = self.dispatch_request()
examples-admin-1 | [admin] File "/usr/lib/python3.6/site-packages/flask/app.py", line 1824, in dispatch_request
examples-admin-1 | [admin] return self.view_functionsrule.endpoint
examples-admin-1 | [admin] File "./api/core.py", line 179, in wrapper
examples-admin-1 | [admin] return call()
examples-admin-1 | [admin] File "./api/core.py", line 144, in call
examples-admin-1 | [admin] ret = func(args, **kwargs)
examples-admin-1 | [admin] File "./endpoints/system/misc.py", line 71, in getDashboardServices
examples-admin-1 | [admin] units = sysd.getServices((service["unit"] for service in known))
examples-admin-1 | [admin] File "./services/systemd.py", line 44, in getServices
examples-admin-1 | [admin] unit["unit"] = unit["unit"].split(" ")[0]
examples-admin-1 | [admin] KeyError: 'unit'
examples-admin-1 [admin] [WARNING] (flask.app) GET /api/v1/system/dashboard/services? from 192.168.178.51 -> 500 '{"message":"The server encountered an error while processing the request."}\n'
Would anyone know where to start looking? I am new to docker so it might be a docker setting on my side.
Best, Chris
