baseline:
Die folgenden 6 Pakete werden aktualisiert:
grommunio-admin-web gromox gromox-debuginfo gromox-debugsource libexmdbpp0
python3-pyexmdb
rpm -qi gromox
Version : 1.5.0.a79c617a
Release : lp153.1.1
Architecture: x86_64
Install Date: Fr 22 Okt 2021 12:55:39
Group : Productivity/Networking/Email/Servers
License : AGPL-3.0-or-later AND GPL-2.0-only AND GPL-3.0-or-later
Signature : RSA/SHA256, Do 21 Okt 2021 22:43:54, Key ID 4f4f3f0138f63abf
Source RPM : gromox-1.5.0.a79c617a-lp153.1.1.src.rpm
Build Date : Do 21 Okt 2021 13:20:09
Build Host : srv-build-01
Relocations : (not relocatable)
Vendor : grommunio GmbH
URL : https://grommunio.com/
Summary : Groupware server backend with RPC, IMAP,POP3, PHP-MAPI support
rpm -qa | egrep '(gromox|grommunio)'
plymouth-theme-grommunio-1-lp153.11.1.noarch
systemd-presets-branding-grommunio-2021.02-lp153.2.1.noarch
grommunio-setup-0.3.48.e71e991-lp153.55.1.noarch
system-user-gromox-2-lp153.9.1.noarch
grommunio-web-1.0.14.5935f111-lp153.8.1.noarch
grommunio-release-2021.08.1-lp153.2.1.x86_64
gromox-debuginfo-1.5.0.a79c617a-lp153.1.1.x86_64
grommunio-imapsync-1.977-lp153.3.1.noarch
grub2-theme-grommunio-1-lp153.11.1.noarch
grommunio-cui-0.3.60.1f82243-lp153.1.1.noarch
grommunio-common-0.0.2-lp153.22.1.noarch
grommunio-chat-5.34.2-lp153.17.1.x86_64
system-user-grommunio-2-lp153.9.1.noarch
grommunio-sync-0.1.53-lp153.46.1.noarch
grommunio-admin-web-2.0.0.0.4c4b553-lp153.1.1.noarch
gromox-debugsource-1.5.0.a79c617a-lp153.1.1.x86_64
grommunio-dav-0.1.12.2064edb-lp153.3.1.noarch
grommunio-admin-common-0.0.1-lp153.18.1.noarch
grommunio-admin-api-1.3.16.a2f660e-lp153.58.1.noarch
gromox-1.5.0.a79c617a-lp153.1.1.x86_64
grommunio-antispam-2.7-lp153.34.1.x86_64
error message:
disconnect from localhost[::1] helo=1 mail=1 rcpt=1 data=1 quit=1 commands=5
[2021-10-22 13:07:32.831791]: connect to ::1[::1]:24: Connection refused
[2021-10-22 13:07:32.844812]: AFC833C59F: to=mail1@domain.com, relay=none, delay=0.12, delays=0.1/0.02/0/0, dsn=4.4.1, status=deferred (connect to ::1[::1]:24: Connection refused)
after:
systemctl --failed
● gromox-delivery-queue.service loaded failed failed Gromox local delivery agent frontend
after using dashboard to restart service
● gromox-delivery.service loaded failed failed Gromox mail spooler
restart in dashboard not working
after reboot ...
check:
seems like https://community.grommunio.com/d/86-solved-mysql-error-in-varlogmysqlmysqldlog-any-idea-howto-fix
mysql error in /var/log/mysql/mysqld.log
2021-10-22 13:33:57 140 [Warning] Access denied for user 'gromm'@'localhost' (using password: NO)
/var/log/gromox/sa.log
2021/10/22 14:06:33 [data_source]: Failed to connect to mysql server, reason: Access denied for user 'gromm'@'localhost' (using password: NO)
quick n dirty like here also not working
https://community.grommunio.com/d/83-pending-mail-is-not-delivered-to-user-not-shwowing-up-in-inbox
