I'm currently migrating to Grommunio. To migrate a few calendars I just want to export them to an ics file and import it in the web interface. This works in general without problems. However, all appointments are shifted by 1 hour. The timezone in the ics file is Europe/Vienna with correct timezone information (DST). But the web interface shows all appointments 1 hour early (e.g. 6am instead of 7am) regardless of DST or not.
My question now is: is there a settings for timezone anywhere? I checked calendar settings, user settings and user settings in admin portal, but did not find anything. Or does this work somehow different?
Thanks!
Timezone setting for user/calendar
An issue was identified and repaired with gromox-2.20-120-g3cb8306c3(community) / gromox-2.20-99-g5278a988b(supported).
I have the same issue on my debian 12 system:
When i import an .ics file in outlook everything is correct. But when i import the.ics file in Webapp full-day appointments are shifted by 2 hours.
Full-day appointments should run from 00:00 to 00:00 but after import they run from 02:00 to 02:00 on the next day.
grommunio-admin-api/unbekannt,now 1.15.1.3b491ef-1+91.1 all [installiert]
grommunio-admin-common/unbekannt,now 35.36c09d4-1+23.1 amd64 [installiert]
grommunio-admin-web/unbekannt,now 2.9.0.49.ad47567-1+82.1 all [installiert]
grommunio-common/unbekannt,now 24.0cedcbe-1+37.2 amd64 [installiert]
grommunio-dav/unbekannt,now 1.3.26.8133bc4-1 all [installiert]
grommunio-error-pages/unbekannt,now 1.0.10.bb2df37-1+10.4 all [installiert]
grommunio-index/unbekannt,now 1.0.1.gd50c1fd-1+54.4 amd64 [installiert]
grommunio-sync/unbekannt,now 2.0.80.655dec9-0 all [installiert]
grommunio-web/unbekannt,now 3.7.11.g8df3c396-1+49.1 all [installiert]
gromox/unbekannt,now 2.26.0.g62e2ca6-1+3.1 amd64 [installiert]
system-user-grommunio/unbekannt,now 3-1 all [Installiert,automatisch]
system-user-gromox/unbekannt,now 6-1 all [installiert]
is there any news on this?
@jengelh
was that also fixed in grommunio-dav? Since many of my calendar appointments / events / holidays are off by one day when I use my calendar in Thunderbird. I created a Ticket#812104 as well.
@jengelh
take a look here please:
It seems that the issue is still present in supported: gromox-2.28.1.256f9d8-1.1.aarch64
GeneralProbe was that also fixed in grommunio-dav?
The change was made to the mapiiCal conversion routines which are located in gromox and which are exercised by g-dav and g-web's Export To ICS function. g-dav didn't specifically need fixing.
