Hi all,
I recently installed grommunio using the Debian-12 packages and migrated the data from my old kopano installation. When I try to sync my Android phone, I get following messages in /var/log/grommunio-sync/grommunio-sync.log
14/01/2024 16:40:51 [ 4371] [ INFO] [xxx@yyy.at] Policy 'devencenabled' not supported by the device, ignoring
14/01/2024 16:40:51 [ 4371] [ INFO] [xxx@yyy.at] cmd='Settings' memory='4.00 MiB/6.00 MiB' time='0.15s' devType='Android' devId='4e696e65363530303432443435444541' getUser='xxx@yyy.at' fr
om='192.168.0.22' idle='0s' version='2.0.49.fe860ff-0' method='POST' httpcode='200'
14/01/2024 16:40:51 [ 4372] [ INFO] [xxx@yyy.at] Policy 'devencenabled' not supported by the device, ignoring
14/01/2024 16:40:51 [ 4372] [ INFO] [xxx@yyy.at] cmd='Settings' memory='4.00 MiB/6.00 MiB' time='0.14s' devType='Android' devId='4e696e65363530303432443435444541' getUser='xxx@yyy.at' fr
14/01/2024 16:40:51 [ 4373] [ INFO] [xxx@yyy.at] Policy 'devencenabled' not supported by the device, ignoring
14/01/2024 16:40:51 [ 4373] [ INFO] [xxx@yyy.at] cmd='Settings' memory='4.00 MiB/6.00 MiB' time='0.15s' devType='Android' devId='4e696e65363530303432443435444541' getUser='xxx@yyy.at' fr
14/01/2024 16:40:51 [ 4374] [ INFO] [xxx@yyy.at] Policy 'devencenabled' not supported by the device, ignoring
14/01/2024 16:40:52 [ 4374] [ WARN] [xxx@yyy.at] StatusException: ExportChangesICS->InitializeExporter(): Error, mapi_exportchanges_config() failed: 0x80004005 - code: 12 - file: /usr/share/grom
munio-sync/lib/grommunio/exporter.php:224
14/01/2024 16:40:52 [ 4374] [ INFO] [xxx@yyy.at] cmd='FolderSync' memory='5.23 MiB/6.00 MiB' time='0.34s' devType='Android' devId='4e696e65363530303432443435444541' getUser='xxx@yyy.at'
from='192.168.0.22' idle='0s' version='2.0.49.fe860ff-0' method='POST' httpcode='200'
14/01/2024 16:40:52 [ 4376] [ INFO] [xxx@yyy.at] Policy 'devencenabled' not supported by the device, ignoring
14/01/2024 16:40:52 [ 4376] [ WARN] [xxx@yyy.at] StatusException: ExportChangesICS->InitializeExporter(): Error, mapi_exportchanges_config() failed: 0x80004005 - code: 12 - file: /usr/share/grom
14/01/2024 16:40:52 [ 4376] [ INFO] [xxx@yyy.at] cmd='FolderSync' memory='5.23 MiB/6.00 MiB' time='0.33s' devType='Android' devId='4e696e65363530303432443435444541' getUser='xxx@yyy.at'
I could not find anything helpful with the WARN message above.
The issue also happens with the appliance.
The issue happens both with Nine sync (Android groupware client) and when I add a Gmail Exchange account.
The result is always that I do not see any emails, contacts or calendar entries on my phone.
I already lost a lot of hair over this and really don't have a lot to spare. Please help me to avoid premature baldness. :-)
Any help would be highly appreciated.
Regards
Clarenze
