WalterH Is /var/lib/systemd/coredump/ empty? Restart time of gromox-http.service: # systemctl status gromox-http.service ● gromox-http.service - Gromox HTTP service Loaded: loaded (/usr/lib/systemd/system/gromox-http.service; enabled; vendor preset: disabled) Active: active (running) since Sun 2024-02-25 16:46:55 CET; 1min 9s ago The line: Active: active (running) since SSSSSS, is SSSSSS the time where the update was installed or a later date?
externa1 yes coredump folder is empty http service active since installation checked all 5 installations
WalterH Development found the issue, we use sendmail to forward mails, gromox.cfg:outgoing_smtp_url=smtp://%3a%3a1. Unfortunately libvmime cores while parsing %3a%3a1. The solution is, replace %3a%3a1 with localhost. The new parameter is: gromox.cfg:outgoing_smtp_url=smtp://localhost Hope this helps someone.
jengelh smtp://%3a%3a1/ is not a valid URL as far as standards are concerned. Because it's nonstandard, the parsing is not well-defined. smtp://[::1]/ is better. Fix1/gromox-2.24-61-gfb7cd038c, Fix2/vmime.
segro the ipv6 ::1 is not working for me: outgoing_smtp_url=smtp://localhost ;outgoing_smtp_url=smtp://[::1]/ I had t user localhost. Apr 29 12:48:29 mail.xxxxxx.de http[189699]: Malformed URL: outgoing_smtp_url="smtp://[::1]/": Malformed URL: Port can only contain digits.
WalterH Simply remark the outgoing_smtp_url entry like: # outgoing_smtp_url=smtp://localhost So the default value is used. https://docs.grommunio.com/man/delivery.8gx.html?highlight=outgoing_smtp_url
