• Bug
  • Active Directory: LDAP Sync with STARTTLS is not working
My Active Directory is configured to accept STARTTLS connections at Port 389. This works well and is confirmed working as my > 5 years old Kopano, as well as my Sophos XG firewall is using the identical configuration. Anyway, when disabling STARTTLS and restarting NGINX at Grommunio Admin it is working without any problems -- once STARTTLS is enabled again, you cannot login anymore.
I have already copied my domain's CA (file extension *.crt) to
/usr/share/pki/trust/anchors/
and added it to the list of trusted CAs by running
update-ca-certificates
which also means that I can confirm, that STARTTLS is working, since I already can sync Users and import Users with STARTTLS enabled, but none of the users will be able to login to webmail. Disable STARTTLS again and restart NGINX, and it works again!
In Monitoring > ZCore the following log entries are created:
[2024-03-24 20:01:19.453714]: ldap_start_tls_s: Connect error
[2024-03-24 20:01:19.454189]: ldap_adaptor: search with base "dc=ads,dc=domain,dc=tld" filter "mail=user@domain.tld": Can't contact LDAP server
Furthermore, every time you hit Save at the LDAP configuration page, the following errors are being displayed, even though the changes are applied correctly:
Configuration updated, but save to disk failed: 1 - Operation not permitted
or
Could not connect to LDAP server: 'NoneType' object has no attribute 'start_tls'
My LDAP configuration: /etc/gromox/ldap_adaptor.cfg
# Configuration automatically generated by grommunio-admin.
ldap_disabled=False
ldap_host=ldap://dc1.ads.domain.tld:389/ ldap://dc2.ads.domain.tld:389/
ldap_bind_user=CN=query,OU=accounts,DC=ads,DC=domain,DC=tld
ldap_bind_pass=pass
ldap_start_tls=False
ldap_search_base=dc=ads,dc=domain,dc=tld
ldap_object_id=objectGUID
ldap_mail_attr=mail
ldap_user_displayname=displayName
ldap_user_filter=(&(objectClass=user)(memberOf=CN=GROMMUNIO Users,OU=groups,DC=ads,DC=domain,DC=tld))
ldap_contact_filter=(&(objectclass=contact)(memberOf=CN=GROMMUNIO Contacts,OU=groups,DC=ads,DC=domain,DC=tld))
ldap_user_search_attrs=mail
ldap_user_search_attrs=givenName
ldap_user_search_attrs=cn
ldap_user_search_attrs=sn
ldap_user_search_attrs=name
ldap_user_search_attrs=displayName
ldap_user_templates=common
ldap_user_templates=ActiveDirectory
ldap_user_aliases=otherMailbox
ldap_group_addr=mail
ldap_group_filter=(&(objectclass=group)(memberOf=CN=GROMMUNIO Groups,OU=groups,DC=ads,DC=domain,DC=tld))
ldap_group_name=cn
ldap_group_memberof=memberOf
Affected Appliance Version:
S | Name | Type | Version | Arch | Repository
| branding-grommunio | srcpackage | 1-lp155.17.1 | noarch | grommunio
i | grommunio | pattern | 1-lp155.9.1 | x86_64 | grommunio
i+ | grommunio-admin-api | package | 1.15.1.3b491ef-lp155.33.1 | noarch | grommunio
| grommunio-admin-api | srcpackage | 1.15.1.3b491ef-lp155.33.1 | noarch | grommunio
| grommunio-admin-api-bash-completion | package | 1.15.1.3b491ef-lp155.33.1 | noarch | grommunio
i+ | grommunio-admin-common | package | 35.36c09d4-lp155.20.1 | noarch | grommunio
| grommunio-admin-common | srcpackage | 35.36c09d4-lp155.20.1 | noarch | grommunio
i+ | grommunio-admin-web | package | 2.9.0.49.ad47567-lp155.13.1 | noarch | grommunio
| grommunio-admin-web | srcpackage | 2.9.0.49.ad47567-lp155.13.1 | noarch | grommunio
i+ | grommunio-antispam | package | 3.8.4-lp155.1.1 | x86_64 | grommunio
| grommunio-antispam | srcpackage | 3.8.4-lp155.1.1 | noarch | grommunio
| grommunio-antispam-debuginfo | package | 3.8.4-lp155.1.1 | x86_64 | grommunio
| grommunio-antispam-debugsource | package | 3.8.4-lp155.1.1 | x86_64 | grommunio
| grommunio-archive | package | 1.3.13.g137.d1b0df1b-lp155.6.23 | x86_64 | grommunio
| grommunio-archive | srcpackage | 1.3.13.g137.d1b0df1b-lp155.6.26 | noarch | grommunio
| grommunio-archive | srcpackage | 1.3.13.g137.d1b0df1b-lp155.6.25 | noarch | grommunio
| grommunio-archive | srcpackage | 1.3.13.g137.d1b0df1b-lp155.6.23 | noarch | grommunio
| grommunio-archive | srcpackage | 1.3.13.g137.d1b0df1b-lp155.6.17 | noarch | grommunio
| grommunio-archive-debuginfo | package | 1.3.13.g137.d1b0df1b-lp155.6.23 | x86_64 | grommunio
| grommunio-archive-debugsource | package | 1.3.13.g137.d1b0df1b-lp155.6.23 | x86_64 | grommunio
| grommunio-auth | package | 0.2.16.e187c26-lp155.20.1 | noarch | grommunio
| grommunio-chat | package | 7.8.0-lp155.5.1 | x86_64 | grommunio
i+ | grommunio-common | package | 24.0cedcbe-lp155.21.1 | x86_64 | grommunio
| grommunio-common | srcpackage | 24.0cedcbe-lp155.21.1 | noarch | grommunio
i+ | grommunio-cui | package | 1.0.265.2c7abfc-lp155.26.1 | noarch | grommunio
| grommunio-cui | srcpackage | 1.0.265.2c7abfc-lp155.26.1 | noarch | grommunio
i+ | grommunio-dav | package | 1.3.20.45e9e18-lp155.1.1 | noarch | grommunio
| grommunio-dav | srcpackage | 1.3.20.45e9e18-lp155.1.1 | noarch | grommunio
i+ | grommunio-dbconf | package | 1.1.1.da20a46-lp155.16.1 | x86_64 | grommunio
| grommunio-dbconf | srcpackage | 1.1.1.da20a46-lp155.16.1 | noarch | grommunio
| grommunio-dbconf-debuginfo | package | 1.1.1.da20a46-lp155.16.1 | x86_64 | grommunio
| grommunio-dbconf-debugsource | package | 1.1.1.da20a46-lp155.16.1 | x86_64 | grommunio
i | grommunio-error-pages | package | 1.0.10.bb2df37-lp155.17.1 | noarch | grommunio
| grommunio-error-pages | srcpackage | 1.0.10.bb2df37-lp155.17.1 | noarch | grommunio
| grommunio-files | package | 26.0.12-lp155.4.1 | noarch | grommunio
i+ | grommunio-imapsync | package | 2.264-lp155.2.1 | noarch | grommunio
i+ | grommunio-index | package | 1.0.1.gd50c1fd-lp155.21.1 | x86_64 | grommunio
| grommunio-index | srcpackage | 1.0.1.gd50c1fd-lp155.21.1 | noarch | grommunio
| grommunio-index-debuginfo | package | 1.0.1.gd50c1fd-lp155.21.1 | x86_64 | grommunio
| grommunio-index-debugsource | package | 1.0.1.gd50c1fd-lp155.21.1 | x86_64 | grommunio
| grommunio-keycloak | package | 22.0.5-lp155.3.1 | noarch | grommunio
| grommunio-office | package | 7.4.1-lp155.4.4 | x86_64 | grommunio
| grommunio-office-debuginfo | package | 7.4.1-lp155.4.4 | x86_64 | grommunio
| grommunio-office-fonts | package | 7.4.1-lp155.4.4 | noarch | grommunio
i+ | grommunio-release | package | 2023.11.3-lp155.12.1 | x86_64 | grommunio
| grommunio-release | srcpackage | 2023.11.3-lp155.12.1 | noarch | grommunio
i+ | grommunio-setup | package | 1.0.109.048c9c5-lp155.28.1 | noarch | grommunio
| grommunio-setup | srcpackage | 1.0.109.048c9c5-lp155.28.1 | noarch | grommunio
i+ | grommunio-sync | package | 2.0.80.655dec9-lp155.34.1 | noarch | grommunio
| grommunio-sync | srcpackage | 2.0.80.655dec9-lp155.34.1 | noarch | grommunio
i+ | grommunio-web | package | 3.7.10.5218bbf5-lp155.11.5 | noarch | grommunio
| grommunio-web | srcpackage | 3.7.10.5218bbf5-lp155.11.5 | noarch | grommunio
i+ | grub2-theme-grommunio | package | 1-lp155.17.1 | noarch | grommunio
| jitsi-meet-branding-grommunio | package | 2.0.6726-lp155.11.1 | noarch | grommunio
| jitsi-meet-branding-grommunio | package | 2.0.6726-lp155.10.1 | noarch | grommunio
| jitsi-meet-branding-grommunio | srcpackage | 2.0.6726-lp155.11.1 | noarch | grommunio
| jitsi-meet-branding-grommunio | srcpackage | 2.0.6726-lp155.10.1 | noarch | grommunio
i+ | NAME="grommunio" | product | "2023.11.3" | noarch | (System Packages)
i+ | patterns-grommunio | package | 1-lp155.9.1 | x86_64 | grommunio
| patterns-grommunio | srcpackage | 1-lp155.9.1 | noarch | grommunio
i+ | plymouth-theme-grommunio | package | 1-lp155.17.1 | noarch | grommunio
i | system-user-grommunio | package | 3-lp155.10.6 | noarch | grommunio
v | system-user-grommunio | package | 3-lp155.10.5 | noarch | grommunio
v | system-user-grommunio | package | 3-lp155.10.4 | noarch | grommunio
v | system-user-grommunio | package | 3-lp155.10.3 | noarch | grommunio
v | system-user-grommunio | package | 3-bp155.1.4 | noarch | base
| system-user-grommunio | srcpackage | 3-lp155.10.6 | noarch | grommunio
| system-user-grommunio | srcpackage | 3-lp155.10.5 | noarch | grommunio
| system-user-grommunio | srcpackage | 3-lp155.10.4 | noarch | grommunio
| system-user-grommunio | srcpackage | 3-lp155.10.3 | noarch | grommunio
i+ | systemd-coredump-grommunio | package | 1-lp155.3.1 | noarch | grommunio
| systemd-coredump-grommunio | srcpackage | 1-lp155.3.1 | noarch | grommunio
i | systemd-presets-branding-grommunio | package | 2023.11-lp155.1.1 | noarch | grommunio
| systemd-presets-branding-grommunio | srcpackage | 2023.11-lp155.1.1 | noarch | grommunio
Best regards,
Chris
    ckd ldap_host=ldap://dc1.ads.domain.tld:389/ ldap://dc2.ads.domain.tld:389/
    ldap_bind_pass=pass
    ahhh missed that after all that text :>
    hmm.. have you tried it with openssl ot something just to see which tls versions are available? maybe there is some problem
    • ckd replied to this.
      One more thing I noticed. If you haven't synced for several, you are getting this one on first Sync Users:
      OperationalError: (MySQLdb._exceptions.OperationalError) (2006, 'MySQL server has gone away')
      This appears to be unrelated to STARTTLS though and happens on a fresh installation of the appliance; fully updated. Then simply wait a few seconds, hit Sync Users again and it works!
      journalctl -f
      Mar 25 08:28:30 srv uwsgi[22859]: [ERROR] (tasq) <worker> Traceback (most recent call last):
      Mar 25 08:28:30 srv uwsgi[22859]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/engine/base.py", line 749, in _rollback_impl
      Mar 25 08:28:30 srv uwsgi[22859]: self.engine.dialect.do_rollback(self.connection)
      Mar 25 08:28:30 srv uwsgi[22859]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/dialects/mysql/base.py", line 2501, in do_rollback
      Mar 25 08:28:30 srv uwsgi[22859]: dbapi_connection.rollback()
      Mar 25 08:28:30 srv uwsgi[22859]: MySQLdb._exceptions.OperationalError: (2006, 'MySQL server has gone away')
      Mar 25 08:28:30 srv uwsgi[22859]: The above exception was the direct cause of the following exception:
      Mar 25 08:28:30 srv uwsgi[22859]: Traceback (most recent call last):
      Mar 25 08:28:30 srv uwsgi[22859]: File "./tools/tasq.py", line 83, in dispatch
      Mar 25 08:28:30 srv uwsgi[22859]: func(self, task)
      Mar 25 08:28:30 srv uwsgi[22859]: File "./tools/tasq.py", line 215, in ldapSync
      Mar 25 08:28:30 srv uwsgi[22859]: DB.session.rollback()
      Mar 25 08:28:30 srv uwsgi[22859]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/scoping.py", line 163, in do
      Mar 25 08:28:30 srv uwsgi[22859]: return getattr(self.registry(), name)(*args, **kwargs)
      Mar 25 08:28:30 srv uwsgi[22859]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/session.py", line 1010, in rollback
      Mar 25 08:28:30 srv uwsgi[22859]: self.transaction.rollback()
      Mar 25 08:28:30 srv uwsgi[22859]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/session.py", line 574, in rollback
      Mar 25 08:28:30 srv uwsgi[22859]: util.raise_(rollback_err[1], with_traceback=rollback_err[2])
      Mar 25 08:28:30 srv uwsgi[22859]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/util/compat.py", line 182, in raise_
      Mar 25 08:28:30 srv uwsgi[22859]: raise exception
      Mar 25 08:28:30 srv uwsgi[22859]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/session.py", line 534, in rollback
      Mar 25 08:28:30 srv uwsgi[22859]: t[1].rollback()
      Mar 25 08:28:30 srv uwsgi[22859]: sqlalchemy.exc.OperationalError: (MySQLdb._exceptions.OperationalError) (2006, 'MySQL server has gone away')
      Mar 25 08:28:30 srv uwsgi[22859]: (Background on this error at: http://sqlalche.me/e/13/e3q8)
      Mar 25 08:28:30 srv uwsgi[22859]: [WARNING] (flask.app) POST /api/v1/domains/ldap/downsync?import=false from 203.0.113.2 -> 500 '{"message":"Synchronization failed: OperationalError: (MySQLdb._exceptions.OperationalError) (2006, \'MySQL server has gone away\')"}\n'
      Mar 25 08:28:34 srv uwsgi[22859]: Mon Mar 25 08:28:34 2024 - SIGPIPE: writing to a closed pipe/socket/fd (probably the client disconnected) !!!
      Mar 25 08:28:57 srv rspamd[1731]: (controller) rdns; rdns_parse_reply: DNS request with id 24449 is for different query, ignoring
      Mar 25 08:29:15 srv uwsgi[22859]: [WARNING] (flask.app) PUT /api/v1/system/mconf/authmgr? from 203.0.113.2 -> 500 '{"message":"Configuration updated, but save to disk failed: 1 - Operation not permitted"}\n'
      Mar 25 08:29:15 srv uwsgi[22859]: [WARNING] (flask.app) PUT /api/v1/system/mconf/ldap?force=false from 203.0.113.2 -> 500 '{"message":"Configuration updated, but save to disk failed: 1 - Operation not permitted"}\n'
      crpb
      Yeah sure thing! Works without any problems.
      Command:
      ldapsearch -x -D "query@ads.domain.tld" -b "ou=accounts,dc=ads,dc=domains,dc=tld" -H ldap://dc1.ads.domain.tld:389/ -W sAMAccountName=query -Z
      Result:
      Enter LDAP Password:
      extended LDIF
      LDAPv3
      base <ou=accounts,dc=ads,dc=domain,dc=tld> with scope subtree
      filter: sAMAccountName=query
      requesting: ALL
      query, accounts, ads.domain.tld
      dn: CN=query,OU=accounts,DC=ads,DC=domain,DC=tld
      objectClass: top
      objectClass: person
      objectClass: organizationalPerson
      objectClass: user
      cn: query
      description: LDAP Bind
      givenName: query
      distinguishedName: CN=query,OU=accounts,DC=ads,DC=domain,DC=tld
      instanceType: 4
      whenCreated: 20221023200607.0Z
      whenChanged: 20240316175606.0Z
      displayName: query
      uSNCreated: 22196
      uSNChanged: 2376659
      objectGUID:: 46mztJAdykuXiQ+3fdxchA==
      userAccountControl: 66048
      badPwdCount: 0
      codePage: 0
      countryCode: 0
      badPasswordTime: 133553352062739353
      lastLogoff: 0
      lastLogon: 133553352219140328
      pwdLastSet: 133111034892756837
      primaryGroupID: 513
      objectSid:: AQUAAAAAAAUVAAAAtJSUVcrtAV3lgemOWgQAAA==
      accountExpires: 9223372036854775807
      logonCount: 2
      sAMAccountName: query
      sAMAccountType: 805306368
      userPrincipalName: query@ads.domain.tld
      lockoutTime: 0
      objectCategory: CN=Person,CN=Schema,CN=Configuration,DC=ads,DC=domain,DC=tld
      dSCorePropagationData: 20221024145334.0Z
      dSCorePropagationData: 16010101000000.0Z
      lastLogonTimestamp: 133550853665748559
      mail: query@domain.tld
      search result
      search: 3
      result: 0 Success
      numResponses: 2
      numEntries: 1
      ckd changed the title to Active Directory: LDAP Sync with STARTTLS is not working .
      I guess Grommunio Admin can be special sometimes... after restaring NGINX it now works perfectly. Sorry guys.
      However, some problems still remain, I will summarize them in this post.
      I
      If you haven't synced for several hours, you are getting this one on first Sync Users:
      Then simply wait a few seconds, hit Sync Users again and it works again!
      journalctl -f
      II
      Eevery time you hit Save at the LDAP configuration page, the following errors are being displayed, even though the changes are applied correctly:
      or
