Hi everybody,
problem solved. I used imapsync which we used for migration kolab servers in the past. Easy, fast and reliable.9
to @ckd
Broken encoding was only at Grommunio WEB GUI. At Outlook all massages was OK and was not important how or at which Outlook version I export it and how they was imported into Outlook connected to Grommunio. But thank you for the TIP.
