WalterH So I have recloned my live Grommunio server and applied the following updates (a few more than yesterday but mainly OpenSUSE updates) - this is output of Admin GUI Updates command:-
This system : Grommunio.server
Uptime : 0:02
Load : Last Minute: 0.50, Last 5 Minutes: 0.39, Last 15 Minutes: 0.17
IP Address : 192.168.50.35 192.168.200.35
Executed : /usr/sbin/grommunio-update update community
Start : Mon 2024-07-15 21:05:43 BST
Operation : Update
[36m▶[0m Starting Update (zypper ref && zypper up -y).
[36m▶[0m on repository community.
Credentials = [32m[0m:[31m[0m.
Repository URL = https://download.grommunio.com/community/openSUSE_Leap_15.5/?ssl_verify=no
grep: /etc/yum.repos.d/: No such file or directory
\x1b[31mNo correct package manager found.\x1b[0m │
Repository 'base' is up to date.
Repository 'debug' is up to date.
Repository 'debug-update' is up to date.
Repository 'grommunio' is up to date.
Repository 'repo-backports-update' is up to date.
Repository 'repo-sle-update' is up to date.
Repository 'update' is up to date.
All repositories have been refreshed.
Loading repository data...
Reading installed packages...
The following 13 packages are going to be upgraded:
grommunio-admin-api grommunio-web gromox gromox-debuginfo gromox-debugsource libLLVM15 libonig4 libpython3_6m1_0 libssh2-1 libvmime-suse8 python3 python3-base python3-curses
13 packages to upgrade.
Overall download size: 63.9 MiB. Already cached: 0 B. After the operation, additional 187.0 KiB will be used.
Backend: classic_rpmtrans
Continue? [y/n/v/...? shows all options] (y): y
Retrieving: gromox-debugsource-2.30.38.g713d40b-lp155.23.1.x86_64 (grommunio) (1/13), 1.0 MiB
Retrieving: gromox-debugsource-2.30.38.g713d40b-lp155.23.1.x86_64.rpm [...done (493.7 KiB/s)]
Retrieving: libvmime-suse8-0.9.2.203-lp155.1.2.x86_64 (grommunio) (2/13), 708.2 KiB
Retrieving: libvmime-suse8-0.9.2.203-lp155.1.2.x86_64.rpm [...done (599.1 KiB/s)]
Retrieving: gromox-debuginfo-2.30.38.g713d40b-lp155.23.1.x86_64 (grommunio) (3/13), 17.9 MiB
Retrieving: gromox-debuginfo-2.30.38.g713d40b-lp155.23.1.x86_64.rpm [........done (14.4 MiB/s)]
Retrieving: gromox-2.30.38.g713d40b-lp155.23.1.x86_64 (grommunio) (4/13), 2.2 MiB
Retrieving: gromox-2.30.38.g713d40b-lp155.23.1.x86_64.rpm [....done (2.0 MiB/s)]
Retrieving: grommunio-web-3.9.25.g24c99c75-lp155.100.1.noarch (grommunio) (5/13), 11.3 MiB
Retrieving: grommunio-web-3.9.25.g24c99c75-lp155.100.1.noarch.rpm [......done (10.3 MiB/s)]
Retrieving: libLLVM15-15.0.7-150500.4.9.6.x86_64 (repo-sle-update) (6/13), 21.9 MiB
Retrieving: libLLVM15-15.0.7-150500.4.9.6.x86_64.rpm [............done (21.6 MiB/s)]
Retrieving: libonig4-6.7.0-150000.3.6.1.x86_64 (repo-sle-update) (7/13), 127.6 KiB
Retrieving: libonig4-6.7.0-150000.3.6.1.x86_64.rpm [..done (2.7 KiB/s)]
Retrieving: libssh2-1-1.11.0-150200.9.2.1.x86_64 (repo-sle-update) (8/13), 125.6 KiB
Retrieving: libssh2-1-1.11.0-150200.9.2.1.x86_64.rpm [..done (2.7 KiB/s)]
Retrieving: python3-base-3.6.15-150300.10.65.1.x86_64 (repo-sle-update) (9/13), 7.5 MiB
Retrieving: python3-base-3.6.15-150300.10.65.1.x86_64.rpm [.....done (18.9 MiB/s)]
Retrieving: libpython3_6m1_0-3.6.15-150300.10.65.1.x86_64 (repo-sle-update) (10/13), 874.4 KiB
Retrieving: libpython3_6m1_0-3.6.15-150300.10.65.1.x86_64.rpm [..done (3.1 KiB/s)]
Retrieving: python3-3.6.15-150300.10.65.2.x86_64 (repo-sle-update) (11/13), 87.8 KiB
Retrieving: python3-3.6.15-150300.10.65.2.x86_64.rpm [..done (2.7 KiB/s)]
Retrieving: python3-curses-3.6.15-150300.10.65.2.x86_64 (repo-sle-update) (12/13), 86.1 KiB
Retrieving: python3-curses-3.6.15-150300.10.65.2.x86_64.rpm [..done (2.8 KiB/s)]
Retrieving: grommunio-admin-api-1.15.18.c2253e7-lp155.108.1.noarch (grommunio) (13/13), 220.8 KiB
Retrieving: grommunio-admin-api-1.15.18.c2253e7-lp155.108.1.noarch.rpm [..done (4.2 KiB/s)]
Checking for file conflicts: [...........done]
( 1/13) Installing: gromox-debugsource-2.30.38.g713d40b-lp155.23.1.x86_64 [......done]
( 2/13) Installing: libvmime-suse8-0.9.2.203-lp155.1.2.x86_64 [...done]
( 3/13) Installing: gromox-debuginfo-2.30.38.g713d40b-lp155.23.1.x86_64 [...............................done]
( 4/13) Installing: gromox-2.30.38.g713d40b-lp155.23.1.x86_64 [........done]
( 5/13) Installing: grommunio-web-3.9.25.g24c99c75-lp155.100.1.noarch [.........................done]
( 6/13) Installing: libLLVM15-15.0.7-150500.4.9.6.x86_64 [.......................................done]
( 7/13) Installing: libonig4-6.7.0-150000.3.6.1.x86_64 [..done]
( 8/13) Installing: libssh2-1-1.11.0-150200.9.2.1.x86_64 [..done]
( 9/13) Installing: python3-base-3.6.15-150300.10.65.1.x86_64 [.................done]
(10/13) Installing: libpython3_6m1_0-3.6.15-150300.10.65.1.x86_64 [...done]
(11/13) Installing: python3-3.6.15-150300.10.65.2.x86_64 [..done]
(12/13) Installing: python3-curses-3.6.15-150300.10.65.2.x86_64 [..done]
(13/13) Installing: grommunio-admin-api-1.15.18.c2253e7-lp155.108.1.noarch [....done]
There are running programs which still use files and libraries deleted or updated by recent upgrades. They should be restarted to benefit from the latest updates. Run 'zypper ps -s' to list these programs.
[32m▶[0m Update completed successfully.
[36m▶[0m Updating postfix configuration with new maps if exist
[36m▶[0m Running post-update/upgrade checksdbop: Current database schema: gx-131
[36m▶[0m Checking for pending service restart or reboot
Restarting service firewalld after update: ... done
Restarting service grommunio-cui@tty1 after update: ... done
Restarting service php-fpm after update: ... done
End Update : Mon 2024-07-15 21:06:32 BST
After updates have been applied I now get the following error when attempting to either login to Files via the https://mail.mydomain.com/files or via the sign in to the Nextcloud app on my MacBook.
You asked for the output of 'systemctl --failed' and this is shown below:-
systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
so it seems that there are no failed services. I then performed a reboot of the server and received the following output from the above command
_systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION >
● grommunio-files-cron.service loaded failed failed Run grommunio Files cron-jo>
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed._
This service error goes away after a few minutes as expected.
Opening the Nextcloud client after the reboot returns me back to the original error in post #1. So bug reported is still causing an issue as Files can no longer be opened/used with the current updates.
Any further ideas on this.
