WalterH LDAP no longer works since an update. The filter configuration is damaged. The round brackets are missing in the LDAP contact filter. Incorrect: objectclass=contact, correct: (objectclass=contact). Remedy: add the round brackets to the LDAP Contact Filter and save the LDAP configuration. The screenshot: Another option is, to edit /etc/gromox/ldap_adaptor.cfgand insert the brackets in the line with: ldap_contact_filter=(objectclass=contact) and save the file.
Steakie Alright, i already received a PR for this fix, but wanted to first discuss this internally, whether this is just a workaround or the actual fix. Since this has already been reported twice by now, i'm just going to merge the PR.
crpb "Missetat vollbracht" bestimmt das komma https://github.com/grommunio/admin-web/pull/3/files#diff-6164af142b129e7f43ba12b49a8fe78a6eb86e4b21d565c0252a30e00a298f44R349 " Das sowas nicht die dollen Github Actions von alleine Fixen "
