in the latest version of the rpm the dependencies were corrected also the libvmime package is available in the repo again. Did an dnf upgrade and that’s it.
you could use rpm -q gromox —requires|grep mime to check, output should be:
libvmime-suse.so.8()(64bit)
Cudos goes out to the whole team and the community
