Steakie morbificagent That's funny. I assume that you do not own a license (because the license icon is red) so you shouldn't even be able to fetch updates from supported, only community. This needs to be fixed in the UI as well xD To answer your question, community repositories always get the latest updates first, so choose that tomorrow 🙂
morbificagent Hi Steakie, have updated a few minutes ago but the problem is still there so the virtual users are invisible... Im not sure if your lastest update was part of my updateprocedure. Where can i see if your fix should be installed here? Many thanks
crpb as a reference on the package you should be able to see the git-tag in the version like for admin-web 3.1.0.31.aff32dc-1+104.1 (this was from a debian vm so it might differ a bit) https://github.com/grommunio/admin-web/commits/master/ https://github.com/grommunio/admin-web/commit/aff32dc And on suse i see: grommunio-admin-web 3.1.0.31.aff32dc-lp155.104.1
morbificagent hm. here in my admin interface it shows Version: 3.1.0-31-gaff32dc and its on suse as i have installed the appliance/image version from your website. The fixes from Steakie arent in place here... Have tried to delete the browsercache and the update-panel in the admin ui doesnt find any new update.
crpb EDIT: ahh sorry i only read the first char in the tag and didn't read further. Seems like a typo? 3.1.0-31-gaff32dc OK, tried the switch to shared and a account is gone here too 😛.. @Steakie 👋
morbificagent ;-) no it isnt a typo... but im "happy" that the shared mailboxes are gone at your site too 😛 So we will wait for Steakie...
crpb morbificagent no it isnt a typo Now i see where you get that leading g I think thats either on purpose or also some kind of typo in admin-web.. grom-test-3:~ # rpm -q grommunio-admin-web grommunio-admin-web-3.1.0.31.aff32dc-lp155.104.1.noarch
crpb Yeah, i actually don't see any commit that refers to that bug if i'm not blind https://github.com/grommunio/admin-web/commits/master/ the aff32dc was just that update-dropdown but as it is the latest i assumed it would also have the fix for the admin-web :p
Steakie Hello there, the fix was not made in AWEB, it was a bug in the AAPI. I just found out that it has not yet been merged into master. Our main API developer isn't available right now but i guess, fingers crossed, i'm going to merge it for them.
morbificagent @Steakie @crpb Works here too! Many thanks for the fast support. Think you have a new paying customer :-)
