oscarjones Hello everyone, I started using Grommunio for managing my email communications & i m eager to optimize my setup for better performance and usability. I have been exploring the various configuration options available but I feel a bit overwhelmed by the choices. I would love to hear from those of you who have experience with Grommunio. What are some best practices you have discovered for configuring email settings to enhance performance? Are there specific features or integrations you recommend for improving workflow and productivity? As well, I found these resources when doing research on this; https://community.grommunio.com/d/582-postfix-configuration[what is oracle integration cloud]{https://www.igmguru.com/blog/what-is-oracle-integration-cloud}-for-my-domain If there are common pitfalls or challenges you faced during the setup process I would appreciate any advice on how to avoid them. Thank you……. 🙂
ozy As a rule of thumb, you should get rid of integrated antispam (which user interface is quite limiting) and use an external antispam that will handle DKIM, TLS, and mail queues. This way, you'll offload quite a bit traffic and processing power from Grommunio. A good solution that comes in mind is Proxmox Mail Gateway. Hence, you'll fine tune Proxmox postfix instead of grommunio's.
