So I did upgrade my home server to 15.6 (thank you for the tutorial btw).
But I still get those same mysql errors. It took about 8 hours for the first errors to show up
2024-11-25 21:43:11 0 [Note] Starting MariaDB 10.11.9-MariaDB source revision 0e8fb977b00983d98c4c35e39bc1f36463095938 server_uid CzjX84zIt+PNvBguxsELxwGNBKw= as process 1543
2024-11-25 21:43:11 0 [Note] InnoDB: Compressed tables use zlib 1.2.13
2024-11-25 21:43:11 0 [Note] InnoDB: Number of transaction pools: 1
2024-11-25 21:43:11 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2024-11-25 21:43:11 0 [Note] InnoDB: Using Linux native AIO
2024-11-25 21:43:11 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000MiB, chunk size = 2.000MiB
2024-11-25 21:43:11 0 [Note] InnoDB: Completed initialization of buffer pool
2024-11-25 21:43:11 0 [Note] InnoDB: Buffered log writes (block size=512 bytes)
2024-11-25 21:43:11 0 [Note] InnoDB: End of log at LSN=1770278584
2024-11-25 21:43:11 0 [Note] InnoDB: 128 rollback segments are active.
2024-11-25 21:43:11 0 [Note] InnoDB: Setting file './ibtmp1' size to 12.000MiB. Physically writing the file full; Please wait ...
2024-11-25 21:43:11 0 [Note] InnoDB: File './ibtmp1' size is now 12.000MiB.
2024-11-25 21:43:11 0 [Note] InnoDB: log sequence number 1770278584; transaction id 7312143
2024-11-25 21:43:11 0 [Note] Plugin 'FEEDBACK' is disabled.
2024-11-25 21:43:11 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2024-11-25 21:43:11 0 [Note] Server socket created on IP: '127.0.0.1'.
2024-11-25 21:43:11 0 [Note] /usr/sbin/mysqld: ready for connections.
Version: '10.11.9-MariaDB' socket: '/run/mysql/mysql.sock' port: 3306 MariaDB package
2024-11-25 21:43:12 0 [Note] InnoDB: Buffer pool(s) load completed at 241125 21:43:12
2024-11-26 5:43:12 8 [Warning] Aborted connection 8 to db: 'grommunio' user: 'grommunio' host: 'localhost' (Got timeout reading communication packets)
2024-11-26 5:43:12 19 [Warning] Aborted connection 19 to db: 'grommunio' user: 'grommunio' host: 'localhost' (Got timeout reading communication packets)
2024-11-26 5:43:12 18 [Warning] Aborted connection 18 to db: 'grommunio' user: 'grommunio' host: 'localhost' (Got timeout reading communication packets)
2024-11-26 5:43:12 21 [Warning] Aborted connection 21 to db: 'grommunio' user: 'grommunio' host: 'localhost' (Got timeout reading communication packets)
2024-11-26 5:43:14 13 [Warning] Aborted connection 13 to db: 'grochat' user: 'grochat' host: 'localhost' (Got timeout reading communication packets)
2024-11-26 6:43:12 7286 [Warning] Aborted connection 7286 to db: 'grommunio' user: 'grommunio' host: 'localhost' (Got timeout reading communication packets)
2024-11-26 7:43:12 14579 [Warning] Aborted connection 14579 to db: 'grommunio' user: 'grommunio' host: 'localhost' (Got timeout reading communication packets)
2024-11-26 8:43:12 21855 [Warning] Aborted connection 21855 to db: 'grommunio' user: 'grommunio' host: 'localhost' (Got timeout reading communication packets)
Current mariadb setup is grommunio's vanilla setup, and is of course 15.6:
mail:/usr/libexec/gromox # rpm -qa | grep mariadb
mariadb-errormessages-10.11.9-150600.4.6.1.noarch
mariadb-10.11.9-150600.4.6.1.x86_64
mariadb-client-10.11.9-150600.4.6.1.x86_64
libmariadb3-3.1.22-150600.16.3.x86_64
