• Bug
  • Entries of shared calendars not shown in Outlook in latest version
With the latest version, installed today, I faces with a recurring problem of former times, that the entries of a shared calendar are not shown in Outlook anymore. The shared calendar itselfs is shown but without entries.
Additionally I must give to the use who should see the shared calendar the "Ordner anzeigen" right that he or she can open the shared calendar in the webmail, otherwise the webmail shows a not localized error that the user has not sufficient rights.
Does anyone have the same problem?
Installed versions:
grommunio-dbconf-1.1.1.da20a46-lp155.20.1.x86_64
grommunio-index-1.0.2.gb782c51-lp155.22.2.x86_64
grommunio-setup-1.1.1.026f61a-lp155.34.1.noarch
grommunio-web-3.9.125.ga45cc2e7-lp155.26.3.noarch
grommunio-chat-9.5.1-lp155.1.1.x86_64
patterns-grommunio-1-lp155.9.1.x86_64
grub2-theme-grommunio-1-lp155.17.2.noarch
system-user-grommunio-10-lp155.2.1.noarch
grommunio-archive-1.3.13.g137.d1b0df1b-lp155.6.78.x86_64
grommunio-sync-2.0.122.8573708-lp155.41.1.noarch
jitsi-meet-branding-grommunio-2.0.6726-lp155.11.1.noarch
plymouth-theme-grommunio-1-lp155.17.2.noarch
grommunio-cui-1.0.265.2c7abfc-lp155.65.1.noarch
grommunio-admin-common-38.f4553bd-lp155.27.1.noarch
grommunio-admin-web-3.1.0.36.b3e1844-lp155.19.1.noarch
grommunio-dav-1.3.74.94260cb-lp155.1.1.noarch
grommunio-release-2023.11.3-lp155.12.1.x86_64
systemd-presets-branding-grommunio-2024.06-lp155.2.1.noarch
grommunio-error-pages-1.0.10.bb2df37-lp155.21.1.noarch
grommunio-admin-api-1.16.1.c518902-lp155.43.1.noarch
grommunio-common-24.0cedcbe-lp155.38.1.x86_64
grommunio-antispam-3.9.1-lp155.1.3.x86_64
systemd-coredump-grommunio-1-lp155.3.1.noarch
grommunio-imapsync-2.264-lp155.2.1.noarch
Florian
selbes Problem auch bei uns, Ticket ist bereits erstellt. Kann das System nicht aktualisieren, da dann die Kalender in Outlook leer sind.
Danke,
ich weiß schon, wieso ich bei jedem Update zunächst einen Testlauf mache, ehe ich es ausrolle.
Florian
Fortunatley on my customers system, where the last update was early october this bug does not appear, there the calendars can be shared and the entries are shwon in Outlook.
ja die Kalender mit aktiviertem Cache funktionieren schon länger nicht. Wenn der Haken "freigegebene Ordner herunterladen" raus ist und die Kalender nicht im Cache landen hat es bisher immer funktioniert. Das wurde auch als Workaround so kommuniziert.
Das jetzige Problem hindert mich z.B. Grommunio zu aktualisieren, da danach die Kalender nicht mehr funktionieren. Sehr problematisch bei 260 Usern wovon ein Drittel Outlook nutzt.
Hoffe auf baldige Lösung
  • PRJ likes this.
