@WalterH @crpb Thank you for sharing your scripts
After having run both purge-softdelete and purge-datafiles, I now have 8.6GB on disk, and 14,8GB as mailbox size, which looks okay since running gromox-mbsize shows that those 14GB are deduplicated and compresed to about 8GB.
I've made a quick script myself, that I now run as systemd timer as @crpb already suggested, everyday at 2am
#!/usr/bin/env bash
SCRIPT_BUILD=202411254
GROMOX_MAILDIR_PATH="/var/lib/gromox"
SOFTDELETE_TIMESTAMP="30d20h"
function TrapQuit {
local exitcode=0
if [ "$SCRIPT_GOOD" == true ]; then
log "Cleanup operation finished with success after ${SECONDS} seconds"
exitcode=0
else
log "Cleanup operation failed after ${SECONDS}" "ERROR"
exitcode=1
fi
exit $exitcode
function log {
local log_line="${1}"
local level="${2}"
if [ "${level}" != "" ]; then
log_line="${level}: ${log_line}"
fi
if [ "${level}" == "ERROR" ]; then
SCRIPT_GOOD=false
echo "ERROR: ${log_line}" >> "${LOG_FILE}"
(>&2 echo -e "$log_line")
else
echo "${log_line}" >> "${LOG_FILE}"
echo "${log_line}"
fi
function cleanup {
for maildir in $(grommunio-admin user query maildir | awk '{if ($1~gromox_mail) {print $1}}' gromox="${GROMOX_MAILDIR_PATH}"); do
if [ "$SOFTDELETE_TIMESTAMP" != "" ]; then
log "Purging soft deletions for ${maildir}"
start_time=${SECONDS}
gromox-mbop -d "${maildir}" purge-softdelete -r -t "$SOFTDELETE_TIMESTAMP" IPM_SUBTREE >> "${LOG_FILE}" 2>&1
if [ $? -eq 0 ]; then
log "Operation took $((${SECONDS}-${start_time})) for ${maildir}"
else
log "Failed to purge soft deletions for ${maildir}" "ERROR"
fi
fi
log "Purging datafiles for ${maildir}"
gromox-mbop -d "${maildir}" purge-datafiles >> "${LOG_FILE}" 2>&1
else
log "Failed to purge datafiles for ${maildir}" "ERROR"
fi
done
## ENTRY POINT
trap TrapQuit TERM EXIT HUP QUIT
set -o pipefail
set -o errtrace
SCRIPT_GOOD=true
## Default log file
SCRIPT_NAME=$(basename "$0")
if [ -w /var/log ]; then
LOG_FILE="/var/log/${SCRIPT_NAME}.log"
elif ([ "${HOME}" != "" ] && [ -w "${HOME}" ]); then
LOG_FILE="${HOME}/${SCRIPT_NAME}.log"
elif [ -w . ]; then
LOG_FILE="./${SCRIPT_NAME}.log"
else
LOG_FILE="/tmp/${SCRIPT_NAME}.log"
fi
cleanup
I wonder if we should make a PR for the next grommunio release, since I think this is pretty basic stuff that everybody should have.
What do you guys think ?
