crpb
Before the MGMT GUI crashes, it will list all users, groups in the current view, even though it should only display groups of Domain A. Ten seconds later I get logged out from the MGMT GUI and no logins are possible. I have to restart all grom* services, which are all still running though, they won't crash. In most cases I reboot, as it's still a test environment.
My problem is still, that I am not getting any useful logs, therefore my question, what you want me to do.
[2025-06-30 15:52:26.226251]: SIGINT/SIGQUIT received...killing workers...
[2025-06-30 15:52:27.225732]: worker 1 buried after 1 seconds
[2025-06-30 15:52:27.225732]: goodbye to uWSGI.
[2025-06-30 15:53:04.974875]: [uWSGI] getting INI configuration from /usr/share/grommunio-admin-api/api-config.ini
[2025-06-30 15:53:04.982269]: *** Starting uWSGI 2.0.19.1 (64bit) on [Mon Jun 30 15:53:04 2025] ***
[2025-06-30 15:53:04.982269]: compiled with version: 7.5.0 on 30 October 2024 12:00:00
[2025-06-30 15:53:04.982269]: os: Linux-6.4.0-150600.23.53-default #1 SMP PREEMPT_DYNAMIC Wed Jun 4 05:37:40 UTC 2025 (2d991ff)
[2025-06-30 15:53:04.982269]: nodename: gr
[2025-06-30 15:53:04.982269]: machine: x86_64
[2025-06-30 15:53:04.982269]: clock source: unix
[2025-06-30 15:53:04.982269]: pcre jit disabled
[2025-06-30 15:53:04.982269]: detected number of CPU cores: 2
[2025-06-30 15:53:04.982269]: current working directory: /usr/share/grommunio-admin-api
[2025-06-30 15:53:04.982269]: detected binary path: /usr/sbin/uwsgi
[2025-06-30 15:53:04.982269]: chdir() to /usr/share/grommunio-admin-api
[2025-06-30 15:53:04.982269]: your processes number limit is 15547
[2025-06-30 15:53:04.982269]: your memory page size is 4096 bytes
[2025-06-30 15:53:04.982269]: detected max file descriptor number: 1024
[2025-06-30 15:53:04.982269]: lock engine: pthread robust mutexes
[2025-06-30 15:53:04.982269]: thunder lock: disabled (you can enable it with --thunder-lock)
[2025-06-30 15:53:04.982269]: - SystemD socket activation detected -
[2025-06-30 15:53:04.982269]: uwsgi socket 1 attached to UNIX address /run/grommunio/admin-api.socket fd 3
[2025-06-30 15:53:04.982269]: Python version: 3.6.15 (default, Sep 23 2021, 15:41:43) [GCC]
[2025-06-30 15:53:05.084844]: Python main interpreter initialized at 0x56097b37d200
[2025-06-30 15:53:05.084844]: python threads support enabled
[2025-06-30 15:53:05.084844]: your server socket listen backlog is limited to 100 connections
[2025-06-30 15:53:05.084844]: your mercy for graceful operations on workers is 60 seconds
[2025-06-30 15:53:05.084844]: mapped 208576 bytes (203 KB) for 4 cores
[2025-06-30 15:53:05.084844]: *** Operational MODE: threaded ***
[2025-06-30 15:53:06.560874]: Failed to detect schema version, assuming up-to-date schema
[2025-06-30 15:53:06.561653]: Database connection failed with error 2002: Can't connect to local MySQL server through socket '/run/mysql/mysql.sock' (2)
[2025-06-30 15:53:08.479760]: WSGI app 0 (mountpoint='') ready in 3 seconds on interpreter 0x56097b37d200 pid: 764 (default app)
[2025-06-30 15:53:08.479760]: *** uWSGI is running in multiple interpreter mode ***
[2025-06-30 15:53:08.479760]: spawned uWSGI master process (pid: 764)
[2025-06-30 15:53:08.481309]: spawned uWSGI worker 1 (pid: 1327, cores: 4)
[2025-06-30 15:53:08.484230]: [WARNING] (tasq) Schema version too old (n102 required) - falling back to offline mode.
[2025-06-30 15:54:36.646603]: [WARNING] (flask.app) Database schema version updated detected - reloading ORM
