Since one of the last Updates users get the massage "Session expired, please login again...".
When the massage is ignored and the page is just refreshed/reloaded ... all works until 5 mins of user inactivity again.
_
What I understand from the logs (also Keycloak´s) is that Grommunio-Web-App only ask the IDP after User Interaction + 5 mins for new Auth-Token.
Idea 1: Is there an easy way to disable this "wrong" message?
Idea 2: Can the Grommunio-WebApp/PHP-Pool/Auth-mechanism be changed to ask the IDP by self if needed?
Try to comment out grommunio.php line #66-#71 leads to Webapp Error "Invalid data received from server"
gromox zcore log:
[31mrhost=[94.234.102.63] user= zs_logon_token rejected: Token did not validate[0m
php-fpm.log
[12-Jan-2025 16:31:09] WARNING: [pool grommunio-web-pool] child 4743 said into stderr: "PHP message: grommunio Web user: xxx@xxx.se: authentication failure at MAPI"
[12-Jan-2025 16:31:09] WARNING: [pool grommunio-web-pool] child 2264 said into stderr: "PHP message: grommunio Web user: xxx@xxx.se: authentication failure at MAPI"
[12-Jan-2025 16:36:09] WARNING: [pool grommunio-web-pool] child 1670 said into stderr: "PHP message: grommunio Web user: xxx@xxx.se: authentication failure at MAPI"
[12-Jan-2025 16:36:09] WARNING: [pool grommunio-web-pool] child 2264 said into stderr: "PHP message: grommunio Web user: xxx@xxx.se: authentication failure at MAPI"
nginx-web-error.log
`2025/01/12 16:31:09 [error] 1696#1696: *13530 FastCGI sent in stderr: "PHP message: grommunio Web user: xxx@xxx.se: authentication failure at MAPI" while reading response header from upstream, client: 94.234.102.63, server: _, request: "POST /web/grommunio.php?subsystem=webapp_1736693484063 HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-web-fpm.sock:", host: "mail.xxxx.se"
2025/01/12 16:36:09 [error] 1696#1696: *13946 FastCGI sent in stderr: "PHP message: grommunio Web user: xxx@xxx.se: authentication failure at MAPI" while reading response header from upstream, client: 94.234.102.63, server: _, request: "POST /web/grommunio.php?subsystem=webapp_1736696017463 HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-web-fpm.sock:", host: "mail.xxxx.se"
2025/01/12 16:36:09 [error] 1696#1696: *13945 FastCGI sent in stderr: "PHP message: grommunio Web user: xxx@xxx.se: authentication failure at MAPI" while reading response header from upstream, client: 94.234.102.63, server: _, request: "POST /web/grommunio.php?subsystem=webapp_1736696017463 HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-web-fpm.sock:", host: "mail.xxxx.se"
System-Information:
switched repository from Subscription to Community to check, but no changes. Now on:
grommunio-admin-api-1.16.11.23c560a-lp155.125.1.noarch
grommunio-admin-common-38.f4553bd-lp155.30.1.noarch
grommunio-admin-web-3.1.0.60.d69e9f4-lp155.115.1.noarch
grommunio-antispam-3.10.2-lp155.1.4.x86_64
grommunio-auth-0.2.18.d93e151-lp155.33.1.noarch
grommunio-common-26.a6f127d-lp155.43.1.x86_64
grommunio-cui-1.0.273.9a6e6de-lp155.74.1.noarch
grommunio-dav-1.3.74.94260cb-lp155.4.1.noarch
grommunio-dbconf-1.1.1.da20a46-lp155.23.1.x86_64
grommunio-error-pages-1.0.10.bb2df37-lp155.24.1.noarch
grommunio-imapsync-2.264-lp155.2.1.noarch
grommunio-index-1.2.3.gc345703-lp155.90.1.x86_64
grommunio-release-2023.11.3-lp155.12.1.x86_64
grommunio-setup-1.1.9.718dcd5-lp155.59.1.noarch
grommunio-sync-2.0.141.9aa611d-lp155.180.1.noarch
grommunio-web-3.9.231.g35325e7b-lp155.181.1.noarch
gromox-2.38.77.gcc7528b-lp155.52.1.x86_64
gromox-debuginfo-2.38.77.gcc7528b-lp155.52.1.x86_64
gromox-debugsource-2.38.77.gcc7528b-lp155.52.1.x86_64
