Dear community ,
a little suggest, how you can improve the security of your grommunio system.
First of all, my appliance is installed with the grommunio.x86_64-latest.install.iso
A.
Add a user instead of working as root:
sudo useradd -s /bin/bash -m myuser
sudo passwd myuser
su myuser
cd ~
#-# add your private key here
mkdir .ssh && echo "ssh-ed25519 XXXXXXX" >> .ssh/authorized_keys
B.
harden your ssh config:
sudo vi /etc/ssh/sshd_config
change or add these lines:
#-#Hardening 2025
#-# If you want to listen ssh only e.g. to your ipv4 ip
ListenAddress 1.2.3.4
PasswordAuthentication no
PubkeyAuthentication yes
PermitRootLogin no
UsePAM no
#-#optional
PrintMotd yes
#-#restart services and check logs:
sudo systemctl restart sshd
sudo journalctl -u sshd
C. tired of failed logins and ssh brute forcing?
Use the onboard firewall!!
- remove all administrative ports from the firewall
sudo firewall-cmd --zone=public --remove-port=22/tcp --permanent
sudo firewall-cmd --zone=public --remove-port=8443/tcp --permanent
sudo firewall-cmd --zone=public --remove-port=8080/tcp --permanent
sudo firewall-cmd --zone=public --remove-service=ssh --permanent
- create a bash skript to allow these ports only from a defined IP ( in my case, my changing home IP)
#!/bin/bash
date="$(date +'%Y-%m-%d %H:%M:%S')"
if [[ $EUID -ne 0 ]]; then
echo "This script must be run as root"
exit 1
fi
#query your now IPs
new_ip=$( dig +short XXX.myfritz.net)
echo $new_ip
new_ipv6=$( dig +short XXX.myfritz.net AAAA)
echo $new_ipv6
#get your old IPs
old_ip=$(sudo firewall-cmd --zone=public --list-rich-rules | grep 'port="22"' |grep ipv4 | head -n 1 | cut -d '"' -f 4)
old_ipv6=$(sudo firewall-cmd --zone=public --list-rich-rules | grep 'port="22"' |grep ipv6 | head -n 1 | cut -d '"' -f 4)
if [ "$new_ip" = "$old_ip" ] ; then
echo $date: IP address has not changed
else
#remove the rules for your old ip
sudo firewall-cmd --zone=public --remove-rich-rule='rule family="ipv4" source address='$old_ip' port protocol="tcp" port="22" accept' --permanent
sudo firewall-cmd --zone=public --remove-rich-rule='rule family="ipv4" source address='$old_ip' port protocol="tcp" port="8443" accept' --permanent
sudo firewall-cmd --zone=public --remove-rich-rule='rule family="ipv4" source address='$old_ip' port protocol="tcp" port="8080" accept' --permanent
sudo firewall-cmd --zone=public --remove-rich-rule='rule family="ipv6" source address='$old_ipv6' port protocol="tcp" port="22" accept' --permanent
sudo firewall-cmd --zone=public --remove-rich-rule='rule family="ipv6" source address='$old_ipv6' port protocol="tcp" port="8443" accept' --permanent
sudo firewall-cmd --zone=public --remove-rich-rule='rule family="ipv6" source address='$old_ipv6' port protocol="tcp" port="8080" accept' --permanent
#add the rules for your new ip
sudo firewall-cmd --zone=public --add-rich-rule='rule family="ipv4" source address='$new_ip' port protocol="tcp" port="22" accept' --permanent
sudo firewall-cmd --zone=public --add-rich-rule='rule family="ipv4" source address='$new_ip' port protocol="tcp" port="8443" accept' --permanent
sudo firewall-cmd --zone=public --add-rich-rule='rule family="ipv4" source address='$new_ip' port protocol="tcp" port="8080" accept' --permanent
sudo firewall-cmd --zone=public --add-rich-rule='rule family="ipv6" source address='$new_ipv6' port protocol="tcp" port="22" accept' --permanent
sudo firewall-cmd --zone=public --add-rich-rule='rule family="ipv6" source address='$new_ipv6' port protocol="tcp" port="8443" accept' --permanent
sudo firewall-cmd --zone=public --add-rich-rule='rule family="ipv6" source address='$new_ipv6' port protocol="tcp" port="8080" accept' --permanent
#reload the services
sudo firewall-cmd --reload
echo $date: firewall-cmd has been updated
fi
3.
#Reload the firewall to apply changes
#Verify the rules
- create a cron as root!
#update dyndnsip from which ssh port 22 is allowed
*/15 * * * * bash /home/myuser/firewall.sh >> /var/log/dyndns-firewall.log 2>&1
- hide the nginx version
/usr/share/grommunio-common> sudo vi nginx.conf
in this section
server {
listen 80;
listen [::]:80;
server_name _;
return 301 https://$host$request_uri;
include /usr/share/grommunio-common/nginx/traffic_status_params*.conf;
#add this
server_tokens off;
- Reboot your system and do a nmap scan from your home ip and another ip to check the open ports
In my case only port 25,80,443,587 are open from any public
@Grommunio Team . your are welcome to implement this in your grommunio setup.
@community - any other advices welcome.
best regards
