First of all. Do we need vt-x/ept? Or could it be deactivated on your side before export? Can't start without saying yes and then my vcenter deactivated it anyway.. Just found that..
So my third import. today. If i say yes it boots. Shutdown .. boot.. Question again.. Answer with no.. will fail the bootprocess.
After an manual/tasked Upgrade
vmware tools missing. They are installed automatically when something different is installed. Just as a note' Seems they are just outdated ot something.. .
/var/log/zypp/history
2021-12-10 13:25:38|install|open-vm-tools|11.2.5-1.17|x86_64|root@srv-build-01|5a0a35cfebea4e1c3afb1e8e028c85b9|bf31d96de0836d44852fdc6f1b994e1397b546cff1ec7d309267f177fa0d8597|
v | repo-sle-update | open-vm-tools | 11.2.5-1.17 | 11.3.5-13.1 | x86_64
[root@esx-2021:~] vmware -v
VMware ESXi 7.0.2 build-18538813
lshw
Guest OS: Other 5.x or later Linux (64-bit)
Compatibility: ESX/ESXi 4.0 and later (VM version 7)
VMware Tools: Running, version:11333 (Guest Managed)
cpu-capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss syscall nx rdtscp x86-64 constant_tsc arch_perfmon nopl tsc_reliable nonstop_tsc cpuid pni pclmulqdq ssse3 cx16 sse4_1 sse4_2 movbe popcnt aes hypervisor lahf_lm 3dnowprefetch pti arat
After upgrade
Compatibility: ESXi 7.0 U2 and later (VM version 19)
cpu-capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss syscall nx pdpe1gb rdtscp x86-64 constant_tsc arch_perfmon nopl xtopology tsc_reliable nonstop_tsc cpuid pni pclmulqdq vmx ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 invpcid rdseed adx smap xsaveopt arat md_clear flush_l1d arch_capabilities
And do you need the Floppy for anything or could you already do an echo blacklist floppy >> /etc/modprobe.d/99-local i think. :-)
