Hallo, ich habe seit dem Update Supported von Gestern auch das Problem.
Und auch wenn ich die Community Version nehme.
Im Spamfilter sieht man die E-mail aber es wird nicht zugestellt, bzw. sieht man es im Postfach nicht.
Im Antispam ist das hier zu lesen.
[2025-08-02 11:58:44.562443]: (rspamd_proxy) <a4b62b>; milter; rspamd_milter_process_command: got connection from 209.85.167.178:54682
[2025-08-02 11:58:44.829948]: (normal) <44e13c>; task; rspamd_worker_body_handler: accepted connection from 127.0.0.1 port 49754, task ptr: 000000003F7C2A78
[2025-08-02 11:58:44.830315]: (normal) <a4b62b>; task; rspamd_mime_part_get_cte: detected missing CTE for part as: 7bit
[2025-08-02 11:58:44.830401]: (normal) <a4b62b>; task; rspamd_message_parse: loaded message; id: <CAFR1=s7mKz9O9HNactt_gRDqJHZNbgahxF0nZ5MPH3dEQ0JcGg@mail.gmail.com>; queue-id: <892056CE4EA>; size: 2950; checksum: <3a9ed1014883ea94ef45ad6e9e48acee>
[2025-08-02 11:58:44.933692]: (normal) <a4b62b>; task; dkim_module_key_handler: stored DKIM key for 20230601._domainkey.gmail.com in LRU cache for 600 seconds, 2/2000 elements in the cache
[2025-08-02 11:58:44.972494]: (normal) <a4b62b>; task; rspamd_spf_maybe_return: stored SPF record for gmail.com (0x2b49dba2c7c4466b) in LRU cache for 300 seconds, 2/2000 elements in the cache
[2025-08-02 11:58:44.998134]: (normal) <a4b62b>; lua; arc.lua:754: cannot read key from /var/lib/grommunio-antispam/arc/2getonline.com.arc.key: Datei oder Verzeichnis nicht gefunden
[2025-08-02 11:58:45.206497]: (normal) <a4b62b>; lua; greylist.lua:360: Score too low - skip greylisting
[2025-08-02 11:58:45.209763]: (normal) <a4b62b>; task; rspamd_task_write_log: id: <CAFR1=s7mKz9O9HNactt_gRDqJHZNbgahxF0nZ5MPH3dEQ0JcGg@mail.gmail.com>, qid: <892056CE4EA>, ip: 209.85.167.178, from: <guenterbrawn@gmail.com>, (default: F (no action): [-0.50/15.00] [DMARC_POLICY_ALLOW(-0.50){gmail.com;none;},R_PARTS_DIFFER(0.50){100.0%;},R_DKIM_ALLOW(-0.20){gmail.com:s=20230601;},R_SPF_ALLOW(-0.20){+ip4:209.85.128.0/17;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},ARC_NA(0.00){},ASN(0.00){asn:15169, ipnet:209.85.128.0/17, country:US;},DKIM_TRACE(0.00){gmail.com:+;},DNSWL_BLOCKED(0.00){209.85.167.178:from;},DWL_DNSWL_BLOCKED(0.00){gmail.com:dkim;},FREEMAIL_ENVFROM(0.00){gmail.com;},FREEMAIL_FROM(0.00){gmail.com;},FROM_EQ_ENVFROM(0.00){},FROM_HAS_DN(0.00){},MID_RHS_MATCH_FROMTLD(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},MISSING_XM_UA(0.00){},NEURAL_SPAM(0.00){1.000;},PREVIOUSLY_DELIVERED(0.00){g.bailey@2getonline.com;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_ONE(0.00){1;},RCVD_TLS_LAST(0.00){},RWL_MAILSPIKE_POSSIBLE(0.00){209.85.167.178:from;},TAGGED_FROM(0.00){},TO_DN_NONE(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 2950, time: 377.040ms, dns req: 23, digest: <441a9215c410c45c579ad996b45490d9>, rcpts: <g.bailey@2getonline.com>, mime_rcpts: <g.bailey@2getonline.com>
[2025-08-02 11:58:45.209763]: (normal) <a4b62b>; task; rspamd_protocol_http_reply: regexp statistics: 76 pcre regexps scanned, 1 regexps matched, 180 regexps total, 11 regexps cached, 4.65KiB scanned using pcre, 4.65KiB scanned total
[2025-08-02 11:58:45.341863]: (rspamd_proxy) <9fffd4>; proxy; proxy_milter_finish_handler: finished milter connection
[2025-08-02 11:58:45.792770]: (rspamd_proxy) <1fe0f5>; milter; rspamd_milter_process_command: got connection from 80.94.95.229:32830
[2025-08-02 11:58:45.792770]: (rspamd_proxy) <1fe0f5>; proxy; proxy_milter_finish_handler: finished milter connection
[2025-08-02 11:58:45.987749]: (rspamd_proxy) <81c0b9>; milter; rspamd_milter_process_command: got connection from 193.46.255.185:59384
[2025-08-02 11:58:45.987749]: (rspamd_proxy) <81c0b9>; proxy; proxy_milter_finish_handler: finished milter connection
Im Postfix Log ist das zu lesen.
[2025-08-02 11:58:45.211652]: 892056CE4EA: from=<guenter.brawn@gmail.com>, size=3415, nrcpt=1 (queue active)
[2025-08-02 11:58:45.216530]: 892056CE4EA: to=<g.bailey@2getonline.com>, relay=::1[::1]:24, delay=0.66, delays=0.65/0/0/0, dsn=2.0.0, status=sent (250 Ok queue-id: 20)
[2025-08-02 11:58:45.216859]: 892056CE4EA: removed
[2025-08-02 11:58:45.342398]: disconnect from mail-oi1-f178.google.com[209.85.167.178] ehlo=2 starttls=1 mail=1 rcpt=1 data=1 quit=1 commands=7
[2025-08-02 11:58:45.724915]: warning: unknown[80.94.95.229]: SASL LOGIN authentication failed: authentication failure, sasl_username=ashlee@2getonline.com
Die Installierten Pakete
system-user-gromox-9-lp156.5.1.noarch
gromox-2.48.5.g6783d70-lp156.6.1.x86_64
gromox-debuginfo-2.48.5.g6783d70-lp156.6.1.x86_64
gromox-debugsource-2.48.5.g6783d70-lp156.6.1.x86_64
grommunio-cui-1.1.1.6b3ec18-lp156.4.1.noarch
grommunio-dav-1.5.5.2ce16ec-lp156.1.1.noarch
plymouth-theme-grommunio-1-lp156.20.1.noarch
system-user-grommunio-10-lp156.2.1.noarch
grommunio-imapsync-2.290-lp156.1.1.noarch
grommunio-web-3.14-lp156.268.1.noarch
grub2-theme-grommunio-1-lp156.20.1.noarch
grommunio-admin-common-42.e17ec55-lp156.32.1.noarch
grommunio-error-pages-1.0.10.bb2df37-lp156.15.1.noarch
systemd-presets-branding-grommunio-2024.06-lp156.2.1.noarch
grommunio-dbconf-1.1.1.da20a46-lp156.9.1.x86_64
grommunio-common-28.1-lp156.8.1.x86_64
systemd-coredump-grommunio-1-lp156.3.1.noarch
patterns-grommunio-1-lp156.9.1.x86_64
grommunio-setup-1.1.13.4ec354b-lp156.67.1.noarch
grommunio-release-2025.1.2-lp156.3.1.x86_64
grommunio-admin-web-4.0.0.8.fe31da5-lp156.131.1.noarch
grommunio-index-1.3.0.g2bd8a8c-lp156.4.1.x86_64
grommunio-admin-api-1.17.9.932eaca-lp156.310.1.noarch
grommunio-antispam-3.12.1-lp156.1.1.x86_64
grommunio-sync-2.2.4.8c6a560-lp156.2.1.noarch
postfix-mysql-3.8.4-150600.3.3.1.x86_64
postfix-3.8.4-150600.3.3.1.x86_64
kann das auch der Spamfilter sein?
Lg
