A few weeks ago, I upgraded a test computer from "2023.11.3" to "2025.1.2" (community version) using the instructions in "A recipe to update grommunio from Open SuSE 15.5 to 15.6." It worked (almost) perfectly, thanks to WalterH.
After the upgrade, the "message list" was no longer displayed in the web interface. According to "https://community.grommunio.com/d/2070-calendar-hangs-after-creating-event-in-web-interface-spinning-circle," this was supposed to be a temporary issue, which, according to the history, should have been resolved with "grommunio-web" version 3.13, which was installed during the upgrade. Yesterday, I performed another update on the test computer. "grommunio-web" was updated from 3.13.13 to 3.13.16. Unfortunately, the problem persists. I was using Firefox on Linux and a current Edge on Windows. The Edge browser has never been connected to Grommunio, so it can't be a hidden cache problem. With preview enabled, the message list works.
Is anyone else experiencing this issue after the upgrade/update, or have I missed something?
Thanks in advance,
Poldi
