I've recently made the switch from Kopano to Grommunio (finally!), and overall it's working well - I'm pretty happy with it so far, though I'm still learning about the new environment.
However, something that is definitely not working (100% reproducible) is the
Rules / "Forward the message as attachment to..." setting in WebApp.
When this rule triggers, the forwarded attachment is either empty or contains what looks like garbled MAPI internal binary data. It doesn’t resemble the original message that was supposed to be attached.
Is this a known bug? Should this feature work?
I don't believe I've misconfigured anything, but since I'm running Grommunio on Debian 12 (so far not a well trodden path) it's possible I’ve missed some required permissions or a tmp directory setup.
I've tried a few different builds of Gromox over the past two weeks, but the behavior hasn't changed. Here's the relevant installation history:
2025-06-15 21:59:40 status installed gromox:amd64 2.46.7.g7b00131-1+8.1
2025-06-17 21:59:20 status installed gromox:amd64 2.46.19.g3580e1c-1+14.1
2025-06-24 14:35:05 status installed gromox:amd64 2.46.26.g3fb2a18-1+21.1
2025-06-30 19:22:27 status installed gromox:amd64 2.46.34.g1e1f63a-1+25.1
Thanks in advance for any insight!
PS: the "redirect the message to" / "forward the message to" seem to work. The difference seems to be that forward changes the Return-Path header while redirect does not. HOWEVER no matter which way the mail is forwarded, it is never in the "Sent" Folder. I think it should be? That is what it was like in Kopano... Not 100% sure about how exchange does this.
