Thank you for your reaction. That's how I started. However I don't get the python script kbd-uidextract not executed because it fails on user SYSTEM in Kopano.
It says:
[error ] HrLogon server "https://nhfserv:237/kopano" user "SYSTEM": logon failed d
So I don't know how /tmp/kdb-uidextract.map should look like'. Ik I only put an account and store UID in it, kopano2grummio.sh says:
18.08.2025 18:26:34 WARN Migration of mailbox me@example.com with Kopano GUID 008CE5A6D2974AA094E5D796801B3766 start
^[[1;31m^[[1;31mCould not open (null) for writing: Bad address. Using stderr.Could not open (null) for writing: Bad address. Using stderr.^[[0m
^[[0m
kdb2mt: ACLs will be extracted and converted.
/tmp/kdb-uidextract.map: parse error
18.08.2025 18:26:34 INFO Mailbox: me@example.conm migrated successfully
18.08.2025 18:26:34 WARN Migration of mailbox me@example.com end
However nothing is written in the Grommunio store.
Again, thanks for Help.
