Unfortunately, I'm still having the same problem.
I followed the installation instructions on the GitHub page.
I left the config file at its default settings.
But the message is still the same: it can't register the passkey.
And it's already entered in Bitwarden.
Tested in follow Browser:
Opera (Linux/Arch)
Chrome (Linux/Arch)
Firefox (Linux/Arch)
Microsoft Edge on Windows10
All the Same Problem.
Im using a Reverse Proxy for my Webinterface is this the problem?
Because I always use a reverse proxy so that I can publish my certificate via the URL.
UPDate:
i have solved the Problem for me.
Set the RP_ID and it works.
However, it seems that it's not working correctly with Bitwarden. It was created, and Bitwarden confirms that it was created, but when logging in, I only have the option to select it via a hardware key.
