❯ apt-cache policy grommunio-web
grommunio-web:
Installed: 3.14.49.g37cafda2c-1+300.1
Candidate: 3.14.49.g37cafda2c-1+303.1
Version table:
3.14.49.g37cafda2c-1+303.1 500
500 https://download.grommunio.com/community/Debian_12 Debian_12/main amd64 Packages
*** 3.14.49.g37cafda2c-1+300.1 100
100 /var/lib/dpkg/status
❯ apt install grommunio-web
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
grommunio-web : Depends: php-cli:any but it is not installable
E: Unable to correct problems, you have held broken packages.
❯ apt-cache depends grommunio-web=3.14.49.g37cafda2c-1+300.1
grommunio-web
Depends: <system-user-groweb>
system-user-grommunio
|Depends: systemd
|Depends: systemd-standalone-sysusers
Depends: <systemd-sysusers>
opensysusers
systemd
Depends: gromox
Depends: php-bcmath
php8.2-bcmath
Depends: php-curl
php8.2-curl
Depends: php-gd
php8.2-gd
Depends: <php-iconv>
php8.2-common
Depends: php-json
libapache2-mod-php8.2
libphp8.2-embed
php8.2-cgi
php8.2-cli
php8.2-fpm
php8.2-phpdbg
Depends: php-mbstring
php8.2-mbstring
Depends: php-sqlite3
php8.2-sqlite3
Depends: <php-sysvshm>
php8.2-common
Depends: php-xml
php8.2-xml
Depends: php-zip
php8.2-zip
Depends: mapi-header-php
Depends: system-user-grommunio
Depends: <php-cli:any> added for build 303
❯ apt-cache depends grommunio-web=3.14.49.g37cafda2c-1+303.1
grommunio-web
|Depends: systemd
opensysusers
systemd
Depends: gromox
Depends: php-bcmath
php8.2-bcmath
Depends: php-curl
php8.2-curl
Depends: php-gd
php8.2-gd
php8.2-common
Depends: php-json
libphp8.2-embed
php8.2-cgi
php8.2-cli
php8.2-fpm
php8.2-phpdbg
php8.2-mbstring
php8.2-sqlite3
php8.2-common
Depends: php-xml
php8.2-xml
Depends: php-zip
php8.2-zip
