i just spin up a vm on localhost and see that i can do this to get your state
... still with community!
localhost:~ # zypper dist-upgrade --dry-run
Loading repository data...
Reading installed packages...
Warning: You are about to do a distribution upgrade with all enabled repositories. Make sure these repositories are compatible before you continue. See 'man zypper' for more information about this command.
Computing distribution upgrade...
Problem: 1: the installed uwsgi-python3-2.0.19.1-150400.8.3.1.x86_64 requires 'uwsgi = 2.0.19.1', but this requirement cannot be provided
not installable providers: uwsgi-2.0.19.1-150400.6.11.x86_64[base]
Solution 1: Following actions will be done:
keep obsolete grommunio-admin-api-1.17.2.73dcb45-lp156.54.1.noarch
keep obsolete python3-openapi-core-0.13.7-lp156.8.1.noarch
Solution 2: Following actions will be done:
deinstallation of grommunio-admin-api-1.17.2.73dcb45-lp156.54.1.noarch
deinstallation of patterns-grommunio-1-lp156.9.1.x86_64
Solution 3: deinstallation of uwsgi-python3-2.0.19.1-150400.8.3.1.x86_64
Solution 4: break uwsgi-python3-2.0.19.1-150400.8.3.1.x86_64 by ignoring some of its dependencies
Choose from above solutions by number or cancel [1/2/3/4/c/d/?] (c): 3
Resolving dependencies...
The following 2 packages are going to be upgraded:
grommunio-admin-api uwsgi
The following 12 packages are going to be downgraded:
grommunio-dbconf grommunio-error-pages grommunio-index libtiff5 python3-Jinja2 python3-PyYAML python3-Werkzeug python3-argcomplete python3-dnspython
python3-openapi-core python3-requests python3-urllib3
The following 6 packages are going to be reinstalled:
grommunio-imapsync grub2-theme-grommunio perl-Encode-IMAPUTF7 plymouth-theme-grommunio python3-pamela python3-rfc3339-validator
The following 62 NEW packages are going to be installed:
libpython3_11-1_0 python3-yarl python311 python311-Flask python311-Jinja2 python311-MarkupSafe python311-PyJWT python311-PyYAML python311-SQLAlchemy
python311-Werkzeug python311-anyio python311-apipkg python311-argcomplete python311-async_timeout python311-attrs python311-base python311-blinker
python311-certifi python311-cffi python311-charset-normalizer python311-click python311-cryptography python311-dnspython python311-greenlet python311-h11
python311-httpcore python311-httpx python311-idna python311-iniconfig python311-isodate python311-itsdangerous python311-jsonschema
python311-lazy-object-proxy python311-ldap3 python311-mattermostdriver python311-more-itertools python311-multidict python311-mysqlclient
python311-openapi-core python311-openapi-schema-validator python311-openapi-spec-validator python311-parse python311-psutil python311-py python311-pyOpenSSL
python311-pyasn1 python311-pycparser python311-pyexmdb python311-pyrsistent python311-redis python311-requests python311-requests-toolbelt
python311-rfc3339-validator python311-setuptools python311-six python311-sniffio python311-strict-rfc3339 python311-systemd python311-typing_extensions
python311-urllib3 python311-uwsgi-python3 python311-websockets
The following package is going to be REMOVED:
uwsgi-python3
2 packages to upgrade, 12 to downgrade, 62 new, 6 to reinstall, 1 to remove.
Package download size:
| 33.4 MiB overall package size
31.6 MiB | - 1.8 MiB already in cache
Package install size change:
| 170.3 MiB required by packages that will be installed
156.7 MiB | - 13.6 MiB released by packages that will be removed
Backend: classic_rpmtrans --dry-run
Continue? [y/n/v/...? shows all options] (y): ?
#1 : y - Yes, accept the summary and proceed with installation/removal of packages.
#2 : n - No, cancel the operation.
#3 : v - Toggle display of package versions.
#4 : a - Toggle display of package architectures.
#5 : r - Toggle display of repositories from which the packages will be installed.
#6 : m - Toggle display of package vendor names.
#7 : d - Toggle between showing all details and as few details as possible.
#8 : g - View the summary in pager.
[y/n/v/...? shows all options] (y): v
grommunio-admin-api 1.17.2.73dcb45-lp156.54.1 -> 1.17.32.021a23c-lp156.1.1
uwsgi 2.0.19.1-150400.8.3.1 -> 2.0.31-lp156.1.1
grommunio-dbconf 1.1.1.da20a46-lp156.30.1 -> 1.1.1.da20a46-lp156.13.1
grommunio-error-pages 1.0.10.bb2df37-lp156.31.1 -> 1.0.10.bb2df37-lp156.22.1
grommunio-index 1.3.0.g2bd8a8c-lp156.40.1 -> 1.3.0.g2bd8a8c-lp156.15.2
libtiff5 4.0.9-150000.45.47.1 -> 4.0.9-150000.45.41.1
python3-Jinja2 2.10.1-150000.3.21.1 -> 2.10.1-3.10.2
python3-PyYAML 5.4.1-150300.3.3.1 -> 5.4.1-1.1
python3-Werkzeug 1.0.1-150300.3.8.1 -> 1.0.1-150300.3.3.1
python3-argcomplete 1.9.2-150000.3.8.1 -> 1.9.2-150000.3.5.1
python3-dnspython 1.15.0-150000.3.10.2 -> 1.15.0-150000.3.2.1
python3-openapi-core 0.13.7-lp156.8.1 -> 0.5.0-bp156.4.1
python3-requests 2.25.1-150300.3.12.2 -> 2.25.1-150300.3.6.1
python3-urllib3 1.25.10-150300.4.12.1 -> 1.25.10-150300.4.9.1
grommunio-imapsync 2.290-lp156.1.1
grub2-theme-grommunio 1-lp156.20.1
perl-Encode-IMAPUTF7 1.05-lp156.1.1
plymouth-theme-grommunio 1-lp156.20.1
python3-pamela 1.0.0-lp156.4.2
python3-rfc3339-validator 0.1.4-lp156.9.2
libpython3_11-1_0 3.11.13-150600.3.35.1
python3-yarl 1.3.0-150200.3.6.1
python311 3.11.13-150600.3.35.2
python311-Flask 2.3.2-150400.3.6.6
python311-Jinja2 3.1.2-150400.12.14.1
python311-MarkupSafe 2.1.3-150400.11.5.2
python311-PyJWT 2.8.0-150400.8.7.2
python311-PyYAML 6.0.2-150600.10.3.1
python311-SQLAlchemy 2.0.19-150400.6.5.12
python311-Werkzeug 2.3.6-150400.6.12.1
python311-anyio 3.6.2-150400.9.3.6
python311-apipkg 3.0.1-150400.12.6.1
python311-argcomplete 3.3.0-150400.12.12.2
python311-async_timeout 4.0.2-150400.10.7.2
python311-attrs 23.1.0-150400.8.6.1
python311-base 3.11.13-150600.3.35.1
python311-blinker 1.6.2-150400.12.7.4
python311-certifi 2023.7.22-150400.12.6.2
python311-cffi 1.15.1-150400.8.7.2
python311-charset-normalizer 3.1.0-150400.9.7.2
python311-click 8.1.3-150400.7.3.9
python311-cryptography 41.0.3-150600.23.6.1
python311-dnspython 2.3.0-150400.12.6.1
python311-greenlet 3.0.3-150600.1.3
python311-h11 0.14.0-150400.9.6.1
python311-httpcore 0.17.0-150400.9.3.9
python311-httpx 0.24.0-150400.9.5.6
python311-idna 3.4-150400.11.10.1
python311-iniconfig 2.0.0-150400.10.6.1
python311-isodate 0.6.1-150400.12.7.2
python311-itsdangerous 2.1.2-150400.7.3.9
python311-jsonschema 4.17.3-150400.14.6.1
python311-lazy-object-proxy 1.9.0-150400.11.3.1
python311-ldap3 2.9.1-150600.1.2
python311-mattermostdriver 7.3.2-lp156.17.2
python311-more-itertools 9.1.0-150400.3.3.9
python311-multidict 6.0.4-150400.7.7.4
python311-mysqlclient 1.4.6-lp156.3.2
python311-openapi-core 0.13.7-lp156.13.2
python311-openapi-schema-validator 0.1.5-lp156.11.4
python311-openapi-spec-validator 0.2.9-lp156.12.1
python311-parse 1.15.0-lp156.2.2
python311-psutil 5.9.5-150400.6.11.1
python311-py 1.11.0-150400.12.7.2
python311-pyOpenSSL 23.2.0-150400.3.10.1
python311-pyasn1 0.5.0-150400.12.7.2
python311-pycparser 2.21-150400.12.7.2
python311-pyexmdb 1.11.5.1d86314-lp156.306.1
python311-pyrsistent 0.19.3-150400.10.6.1
python311-redis 5.0.1-150600.3.2.1
python311-requests 2.31.0-150400.6.18.1
python311-requests-toolbelt 1.0.0-150400.7.3.8
python311-rfc3339-validator 0.1.4-150400.9.3.9
python311-setuptools 67.7.2-150400.3.19.1
python311-six 1.16.0-150400.18.11.1
python311-sniffio 1.3.0-150400.9.3.9
python311-strict-rfc3339 0.7-150400.10.3.9
python311-systemd 234-lp156.3.2
python311-typing_extensions 4.9.0-150600.1.3
python311-urllib3 2.0.7-150400.7.21.1
python311-uwsgi-python3 2.0.31-lp156.1.1
python311-websockets 11.0.3-150400.10.3.11
uwsgi-python3 2.0.19.1-150400.8.3.1
and on supported....
tried this and that.. anyhow.
started a grommunio-setup with and w/o license data.. same problem with both...
▼ grommunio-setup is updating the system
Repository 'backports-debug-update' is up to date.
Repository 'backports-update' is up to date.
Repository 'debug-update' is up to date.
Repository 'sle-debug-update' is up to date.
Repository 'sle-update' is up to date.
Repository 'update' is up to date.
Repository 'base' is up to date.
Repository 'debug' is up to date.
Repository 'grommunio' is up to date.
Repository 'src' is up to date.
All repositories have been refreshed.
The following package update will NOT be installed:
grommunio-admin-api
The following 9 packages are going to be upgraded:
grommunio-cui grommunio-dbconf grommunio-error-pages grommunio-imapsync grommunio-release gromox gromox-debuginfo gromox-debugsource libHX32
9 packages to upgrade.
Package download size: 26.1 MiB
| 124.2 MiB required by packages that will be installed
4.2 KiB | - 124.2 MiB released by packages that will be removed
Continue? [y/n/v/...? shows all options] (y): y
Retrieving: grommunio-cui-1.1.3.b0091e0-lp156.9.1.noarch (grommunio) (1/9), 61.8 KiB
Retrieving: grommunio-cui-1.1.3.b0091e0-lp156.9.1.noarch.rpm [....done (2.7 KiB/s)]
Retrieving: grommunio-dbconf-1.1.1.da20a46-lp156.36.1.x86_64 (grommunio) (2/9), 27.4 KiB
Retrieving: grommunio-dbconf-1.1.1.da20a46-lp156.36.1.x86_64.rpm [..done (172 B/s)]
Retrieving: grommunio-error-pages-1.0.10.bb2df37-lp156.36.1.noarch (grommunio) (3/9), 24.8 KiB
Retrieving: grommunio-error-pages-1.0.10.bb2df37-lp156.36.1.noarch.rpm [..done (172 B/s)]
Retrieving: grommunio-imapsync-2.290-lp156.2.1.noarch (grommunio) (4/9), 241.3 KiB
Retrieving: grommunio-imapsync-2.290-lp156.2.1.noarch.rpm [..done (172 B/s)]
Retrieving: grommunio-release-2025.1.2-lp156.4.1.x86_64 (grommunio) (5/9), 8.2 KiB
Retrieving: grommunio-release-2025.1.2-lp156.4.1.x86_64.rpm [..done (172 B/s)]
Retrieving: gromox-debugsource-3.1.28.061aefa-lp156.2.1.x86_64 (grommunio) (6/9), 1.1 MiB
Retrieving: gromox-debugsource-3.1.28.061aefa-lp156.2.1.x86_64.rpm [...done (853.0 KiB/s)]
Retrieving: libHX32-4.28-lp156.1.1.x86_64 (grommunio) (7/9), 50.6 KiB
Retrieving: libHX32-4.28-lp156.1.1.x86_64.rpm [..done (172 B/s)]
Retrieving: gromox-debuginfo-3.1.28.061aefa-lp156.2.1.x86_64 (grommunio) (8/9), 22.3 MiB
Retrieving: gromox-debuginfo-3.1.28.061aefa-lp156.2.1.x86_64.rpm [............done (20.2 MiB/s)]
Retrieving: gromox-3.1.28.061aefa-lp156.2.1.x86_64 (grommunio) (9/9), 2.2 MiB
Retrieving: gromox-3.1.28.061aefa-lp156.2.1.x86_64.rpm [...done (643.5 KiB/s)]
Checking for file conflicts: [......done]
(1/9) Installing: grommunio-cui-1.1.3.b0091e0-lp156.9.1.noarch [....
Failed to try-restart grommunio-cui@.service: Unit name grommunio-cui@.service is missing the instance name.
See system logs and 'systemctl status grommunio-cui@.service' for details.
done]
(2/9) Installing: grommunio-dbconf-1.1.1.da20a46-lp156.36.1.x86_64 [..done]
(3/9) Installing: grommunio-error-pages-1.0.10.bb2df37-lp156.36.1.noarch [..done]
(4/9) Installing: grommunio-imapsync-2.290-lp156.2.1.noarch [..done]
(5/9) Installing: grommunio-release-2025.1.2-lp156.4.1.x86_64 [..done]
(6/9) Installing: gromox-debugsource-3.1.28.061aefa-lp156.2.1.x86_64 [....done]
(7/9) Installing: libHX32-4.28-lp156.1.1.x86_64 [..done]
(8/9) Installing: gromox-debuginfo-3.1.28.061aefa-lp156.2.1.x86_64 [.......................done]
(9/9) Installing: gromox-3.1.28.061aefa-lp156.2.1.x86_64 [......done]
'jq' is already installed.
No update candidate for 'jq-1.6-150000.3.9.1.x86_64'. The highest available version is already installed.
'mariadb' is already installed.
No update candidate for 'mariadb-10.11.14-150600.4.14.1.x86_64'. The highest available version is already installed.
'postfix' is already installed.
No update candidate for 'postfix-3.8.4-150600.3.3.1.x86_64'. The highest available version is already installed.
'cyrus-sasl-plain' is already installed.
No update candidate for 'cyrus-sasl-plain-2.1.28-150600.7.6.2.x86_64'. The highest available version is already installed.
'cyrus-sasl-saslauthd' is already installed.
No update candidate for 'cyrus-sasl-saslauthd-2.1.28-150600.7.6.2.x86_64'. The highest available version is already installed.
'php-fpm' not found in package names. Trying capabilities.
'php8-fpm' providing 'php-fpm' is already installed.
'gromox' is already installed.
No update candidate for 'gromox-3.1.28.061aefa-lp156.2.1.x86_64'. The highest available version is already installed.
'grommunio-antispam' is already installed.
No update candidate for 'grommunio-antispam-3.12.1-lp156.1.1.x86_64'. The highest available version is already installed.
'grommunio-common' is already installed.
No update candidate for 'grommunio-common-29.0-lp156.2.1.x86_64'. The highest available version is already installed.
'grommunio-web' is already installed.
No update candidate for 'grommunio-web-3.15.50.g6745d596e-lp156.346.1.noarch'. The highest available version is already installed.
'grommunio-admin-web' is already installed.
No update candidate for 'grommunio-admin-web-4.0.0.21.0ad253e-lp156.144.1.noarch'. The highest available version is already installed.
'grommunio-dav' is already installed.
No update candidate for 'grommunio-dav-1.5.17.c1122c5-lp156.1.1.noarch'. The highest available version is already installed.
'grommunio-sync' is already installed.
No update candidate for 'grommunio-sync-2.3.5.306a709-lp156.18.1.noarch'. The highest available version is already installed.
Resolving package dependencies...
Problem: 1: the to be installed grommunio-admin-api-1.17.32.021a23c-lp156.15.1.noarch requires 'python311-pyexmdb >= 1.10.0', but this requirement cannot be provided
not installable providers: python311-pyexmdb-1.11.5.1d86314-lp156.302.1.x86_64[grommunio]
downgrade of libexmdbpp0-1.11.5.1d86314-lp156.306.1.x86_64 to libexmdbpp0-1.11.5.1d86314-lp156.302.1.x86_64
downgrade of python3-pyexmdb-1.11.5.1d86314-lp156.306.1.x86_64 to python3-pyexmdb-1.11.5.1d86314-lp156.302.1.x86_64
Solution 2: do not install grommunio-admin-api-1.17.32.021a23c-lp156.15.1.noarch
Solution 3: break grommunio-admin-api-1.17.32.021a23c-lp156.15.1.noarch by ignoring some of its dependencies
Choose from above solutions by number or cancel [1/2/3/c/d/?] (c): c
zypper returned with non-zero exit status.
Pausing so you can inspect the log or remedy the issue.
Hit ENTER when ready to continue g-setup with the next step.
EDIT: Oh wait, with no credentials it's the error from above....
EDIT2: So to get it installed i need to install the packages myself upfront /ó\...
eval $(grep -A2 'gromox grommunio-admin-api' /usr/share/grommunio-setup/setup.sh)
zypper --verbose install $PACKAGES
