dneuhaeuser
I received another response from support yesterday that a bug is now finally reproducible, specifically the one where no more emails can be deleted in the online profile when a specific sorting of folders is active in Outlook
Regarding the problem with the duplicate display of emails, and the fact that when you delete them, empty emails are displayed 4 times in the main account, no information was provided whatsoever
I deactivated grommunio-archive, or rather, switched off the delivery of BCCs in Postfix; after doing so, no more duplicate emails arrived in online mode.
I tested this with 3 customers and myself, so 4 times successfully, but all have sortet the mails, i have sortet the mails to and then the showed only one time. so its my mistace archive doesnt help to solve..
Alle That happend only when the focuse is on inbox wenn mail arrived. but when the focuse not at inbox they are not twice mails. this is another problme that i meean the archive is the problem!
. Unfortunately, it doesn't help the online mode is so buggy it is currently unusable because
no emails can be deleted in shared mailboxes, sorting does not work, senders and recipients are missing or emails are displayed as empty. no 3rd party tools via MAPI can write content back into the emails always blanke.
It surprises me that this doesn't help on your end. I just reversed the changes again, reactivated the archive in Postfix, and the emails are displayed as duplicates in Outlook. Perhaps there are multiple factors involved. However, this workaround is not a solution for me, as the other problems are just as bad, and I cannot fix those.
can you check.
after deliting this twice mails i see this on OL 2024. do you have the same.
If the Mailbox online Box is shared you cannot delete maisl when the sorting is on AT ..
Mails are not refreshing after deleting ony by closing ore change mailbox mails are deletet and then in directliy integratet boxes mails are empty see here.
but can you test and confirm this two probleme more..
Mailboxes shared in online.
dubls are here with disabled archive. so it must be another point:
after sorting by at
mails show one time, thats the problem that looked for solfing.. sorry not right.
deleting are not possible after sorting at:
