raspberry-pi-4b
almalinux-10.1-arm64 # Prebuilt image
dnf install epel-release
crb enable
vi /etc/yum.repos.d/grommunio.repo # Add ".../community/EL10/"
dnf update && dnf upgrade
dnf in grommunio-admin-api grommunio-admin-common grommunio-admin-web grommunio-dav grommunio-index grommunio-sync grommunio-web gromox
Last metadata expiration check: 1:00:35 ago on Wed Nov 26 16:10:32 2025.
Error:
Problem 1: conflicting requests
- nothing provides python3-openapi-core >= 0.12.0 needed by grommunio-admin-api-1.17.33.0a2d18a-7.2.noarch from grommunio
- nothing provides python3-lazy-object-proxy needed by grommunio-admin-api-1.17.33.0a2d18a-7.2.noarch from grommunio
- nothing provides python3-mattermostdriver needed by grommunio-admin-api-1.17.33.0a2d18a-7.2.noarch from grommunio
- nothing provides python3-openapi-schema-validator needed by grommunio-admin-api-1.17.33.0a2d18a-7.2.noarch from grommunio
- nothing provides python3-openapi-spec-validator needed by grommunio-admin-api-1.17.33.0a2d18a-7.2.noarch from grommunio
Problem 2: conflicting requests
- nothing provides php-sqlite needed by grommunio-dav-1.5.17.c1122c5-1.18.noarch from grommunio
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
