Hallo zusammen,
wie ich im Admin Handbuch gelesen habe muss man um "Active Sync" zu aktivieren das auf einem Seperaten Server installieren ist das richtig so?
Hier der Auszug aus dem Handbuch:
grommunio Sync
grommunio Sync is an open-source application to synchronize Exchange ActiveSync (EAS) compatible devices such as mobile phones and tablets.
While Microsoft Outlook supports EAS, it is not recommended to use grommunio Sync due to a very small subset of features only supported. For Microsoft Outlook, users should rather use the native MAPI/HTTP and MAPI/RPC protocols, available through grommunio Gromox <https://github.com/grommunio/gromox\>\.
At a glance
Provides native groupware (emails, contacts, calendar, tasks and notes) connectivity for mobile devices, such as phones and tablets.
Delivers Exchange ActiveSync (EAS) 2.5, 12.0, 12.1, 14.0, 14.1, 16.0 and 16.1 protocol compatibility.
Multi-platform support for most recent Android, Apple (iOS powered iPhones and iPads) and even outdated Windows Mobile, Nokia and Blackberry devices.
Supports device management policies such as remote-wipe, password-strength, lockout after invalid authentication after definable amount of times.
Compatible, works with various web servers such as nginx and apache and others; usage of nginx is recommended.
Highly efficient, averaging at 2MB per sync thread per device of memory usage (using nginx with php-fpm).
Distributable, compatible with load balancers such as haproxy, apisix, KEMP and others.
Scalable, enabling multi-server and multi-location deployments.
Failover-safe, storing device and sync states in user stores.
High-performance, allowing nearly wire speeds for store synchronization.
Secure, with certifications through independent security research and validation.
Built with
PHP 7.4+, 8.x
PHP modules: soap, mbstring, posix, pcntl, pdo, xml, redis
PHP backend module: mapi
Getting started
Prerequisites
A working web server (nginx is recommended), with a working TLS configuration.
PHP, preferably available as fpm pool.
Redis for high-performance interprocess communication states.
Zcore MAPI transport (provided by Gromox).
Working AutoDiscover setup (recommended, provided by Gromox).
Installation
Deploy grommunio-sync at a location of your choice, such as /usr/share/grommunio-sync.
Adapt version.php with the adequate version string, see /build/version.php.in.
Provide a default configuration file as config.php, see /config.php.
Adapt web server configuration according to your needs, /build provides some examples.
Prepare PHP configuration according to your needs, /build provides some examples.
Installation and configuration of redis service.
(Optional) setup AutoDiscover accordingly for account discovery and configuration.
Usage
Point your EAS client of choice with the "Microsoft Exchange" mail account type made available.
With AutoDiscover, only your account credentials (username and password) are required for device setup.
Use grommunio-sync-top.php or grommunio Admin UI to view connections.
Weil ich frage deswegen bei Microsoft Exchange ist das einfach ein Unterordner vom Mailserver bzw. Webserver den man dort erreichen muss.
Wenn ich das auf einem Seperaten Server installieren muss geht dabei auch ein Docker Container als Webserver? hat das schon jemand getestet?
Weil finde dafür wäre eine echte VM einfach Verschwendung von Ressourcen.
Danke für eurer Feedback.
