Nur leider lassen sich die neuen Pakete nicht ohne Konflikte installieren :-(
grommunio:~ # zypper install jitsi-meet-branding-grommunio
Loading repository data...
Warning: Repository 'debug-update' appears to be outdated. Consider using a different mirror or server.
Warning: Repository 'repo-backports-debug-update' appears to be outdated. Consider using a different mirror or server.
Reading installed packages...
Resolving package dependencies...
The following 3 NEW packages are going to be installed:
jitsi-meet jitsi-meet-branding-grommunio jitsi-meet-prosody-plugins
3 new packages to install.
Overall download size: 0 B. Already cached: 12.7 MiB. After the operation, additional 40.0 MiB will be used.
Continue? [y/n/v/...? shows all options] (y):
In cache jitsi-meet-prosody-plugins-2.0.6726-lp153.4.4.noarch.rpm (1/3), 206.3 KiB (254.9 KiB unpacked)
In cache jitsi-meet-2.0.6726-lp153.4.4.noarch.rpm (2/3), 12.5 MiB ( 39.6 MiB unpacked)
In cache jitsi-meet-branding-grommunio-2.0.6726-lp153.1.1.noarch.rpm (3/3), 49.9 KiB (194.1 KiB unpacked)
Checking for file conflicts: ................................................................................................................................................................................................................................................[error]
Detected 5 file conflicts:
File /srv/jitsi-meet/base.html
from install of
jitsi-meet-2.0.6726-lp153.4.4.noarch (grommunio)
conflicts with file from install of
jitsi-meet-branding-grommunio-2.0.6726-lp153.1.1.noarch (grommunio)
File /srv/jitsi-meet/images/logo-deep-linking.png
from install of
File /srv/jitsi-meet/images/watermark.svg
from install of
File /srv/jitsi-meet/index.html
from install of
File /srv/jitsi-meet/title.html
from install of
File conflicts happen when two packages attempt to install files with the same name but different contents. If you continue, conflicting files will be replaced losing the previous content.
Continue? [yes/no] (no):
