mwilliams
Just did the big Update.
Is it just me or do special chars break the Search-Function in the Web-Gui?
Everything with "-@." and probably any other non [:alnum:] character seems to break the search.
I also experience problems with the View
This happens to some mails. I couldn't determine any pattern which mails are affected as of yet.
Access via IMAP and Outlook works w/o any problems so far.
I completely removed the sqlite-indexes and did a rebuild. Also tried an removal of all files w/o the manual start of grommunio-index-run.sh for now.
It seems this is periodically run anywar?
gromi:/var/lib/grommunio-web # systemctl list-timers
NEXT LEFT LAST PASSED UNIT ACTIVATES
Wed 2022-05-18 06:00:00 CEST 26min left n/a n/a snapper-timeline.timer snapper-timeline.service
Thu 2022-05-19 00:00:00 CEST 18h left Wed 2022-05-18 00:00:01 CEST 5h 33min ago logrotate.timer logrotate.service
Thu 2022-05-19 00:00:00 CEST 18h left Wed 2022-05-18 00:00:01 CEST 5h 33min ago mandb.timer mandb.service
Thu 2022-05-19 01:02:53 CEST 19h left Wed 2022-05-18 01:35:11 CEST 3h 58min ago grommunio-index.timer grommunio-index.service
Thu 2022-05-19 05:27:40 CEST 23h left Wed 2022-05-18 05:27:40 CEST 6min ago snapper-cleanup.timer snapper-cleanup.service
Thu 2022-05-19 05:32:39 CEST 23h left Wed 2022-05-18 05:32:39 CEST 1min 14s ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
Mon 2022-05-23 01:33:08 CEST 4 days left Mon 2022-05-16 01:29:33 CEST 2 days ago fstrim.timer fstrim.service
7 timers listed.
Pass --all to see loaded but inactive timers, too.
gromi:/var/lib/grommunio-web # systemctl cat grommunio-index.service
# /usr/lib/systemd/system/grommunio-index.service
[Unit]
Description=Fulltext search index regeneration
[Service]
ProtectSystem=full
ProtectHome=true
PrivateDevices=true
ProtectHostname=true
ProtectClock=true
ProtectKernelTunables=true
ProtectKernelModules=true
ProtectKernelLogs=true
ProtectControlGroups=true
RestrictRealtime=true
Type=oneshot
ExecStart=/usr/sbin/grommunio-index-run.sh
Current Version's
gromi:/var/lib/grommunio-web # rpm -qa |grep -E gromox\|grommunio |sort
grommunio-admin-api-1.7.15.26e3c3c-lp153.114.1.noarch
grommunio-admin-common-5.b904016-lp153.8.1.noarch
grommunio-admin-web-2.2.0.21.67d8ce2-lp153.55.1.noarch
grommunio-antispam-3.1-lp153.3.2.x86_64
grommunio-chat-6.2.1-lp153.14.1.x86_64
grommunio-common-5.afb9bdc-lp153.12.1.x86_64
grommunio-cui-1.0.7.edc336c-lp153.11.1.noarch
grommunio-dav-0.1.16.a551294-lp153.2.1.noarch
grommunio-error-pages-1.0.6.9c50afb-lp153.7.1.noarch
grommunio-imapsync-2.200-lp153.4.1.noarch
grommunio-index-0.1.11.8787c3c-lp153.16.1.x86_64
grommunio-release-2022.05.1-lp153.1.1.x86_64
grommunio-setup-1.0.27.350d021-lp153.30.1.noarch
grommunio-sync-0.1.111-lp153.101.1.noarch
grommunio-web-2.10.86.2d86df11-lp153.61.1.noarch
gromox-1.23.0.0dfe52c2c-lp153.32.1.x86_64
gromox-debuginfo-1.23.0.0dfe52c2c-lp153.32.1.x86_64
gromox-debugsource-1.23.0.0dfe52c2c-lp153.32.1.x86_64
grub2-theme-grommunio-1-lp153.11.4.noarch
plymouth-theme-grommunio-1-lp153.11.4.noarch
system-user-grommunio-2-lp153.9.4.noarch
system-user-gromox-2-lp153.9.4.noarch
systemd-presets-branding-grommunio-2021.02-lp153.3.1.noarch
